Hi - set-up is Sony 5200 Amp, Playstations 3, Xbox 360 and Toshiba DLP with HDMI input. Problem I am having is PS3 works perfectly on the TV (HDMI to amp then out to TV) but will not output to the Infocus In76 projector. Projector copes fine with component signal from Xbox with no issues!
Things that have been checked
- Video upscaling turned on and at all settings,
- component input removed from projector
- Checked HDMI cable and it is working
- Checked PS3 direct to Projector with no joy
- Checked HDMI is enabled on projector
Anyone got any ideas? All help appreciated.
Update:
Just spoken to the dealer in relation to this issue. Have been told to lower the output resolution on the PS3 down to 720 to allow a proper handshake to occur between the device. Dont feel so bad now as dealer spent 5 hours trying to solve this problem before finding the answer!
Will be trying this out this evening and will let you all know!
Next challenge will be to find a decent cheap splitter so I dont have to keep swapping the HDMI cable out from the projector. Seen a very cheap solution on ebay $2.99 but not sure if this will work.... then again for that money it is worth a try.
Appreciate the responses to date.
Jack
Update:
Jack
So, get it working!
