I have an image retention question for a neighbor with a two-year old Pio plasma that was broken-in properly. They're Comcast subscribers, which offers few widescreen, 16:9 HD channels — just 13 here in Sacramento. They're pretty careful with the TV. They do no gaming or computer Web surfing on it and I've manually calibrated the display for them with lower brightness/contrast/color saturation settings and made sure the orbiter function is turned on. But given Comcast's lack of HD channels, they do watch a lot of 4:3 SDTV (which Comcast severely over compresses, but that's another story). The neighbors often stretch the 4:3 image to fill the screen (but not always) and I'm starting to notice pillar bars on each side that are blacker than the 4:3 center area of their screen (which actually has a slight black/green cast). They don't use the TV setup with gray pillar bars, which they feel are just too distracting. It is not clear to me whether this would be considered image retention or burn-in, but here are the questions:
1. Can (and should) this be corrected by running a program with gray (or white) pillar bars? If so, should the center area be white or gray?
2. Couldn't a computer slideshow or animated movie be created to run through slides with white/gray pillar bars and a white/gray center area(whatever the consensus is for the correction)? I think you could even even add a faux "orbiter" function by slightly moving the horizontal position of the pillar bars through several slides so that the vertical line is eliminated (or minimized), and then changing these slides every second. You could run this "show" for a few hours...
This Pio display does have an orbiter function that can be turned on for use during viewing, but nothing custom that can be run "after" viewing...
