AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" VSX-94TXH Thread...:0)
The "Official" VSX-94TXH Thread...:0) - Page 98
post #2911 of 4921
I thought it was strange that no one responded to my predicament, but so help me I can't even find the question I posted. So here goes again and apologies to all if it did appear somewhere. I wanted to set up my speakers with the room calibration via the microphone, but I don't end up with anything on my Pioneer Kuro plasma screen, yet the LCD screen of the 94txh shows "Start" when I follow the instructions in the manual for the MCACC approach. What could be the reason for this ? I am using a HDMI connection from the 94txh to the TV. Thanks.
post #2912 of 4921
I can't remember for sure since it been a few months since I setup my 94 but I don't think you will see any info about the MCACC setup sequence on your TV the info just appears on the 94 itself. Don't quote me on this though I could be wrong.
post #2913 of 4921
Originally Posted by maxdog03 View Post
what would happen if you ran a component cable or video cable from the cable box to the video 1 video input along with the CD players output to the video 1 audio inputs? Wouldn't this accomplish the same thing and you wouldn't ever have to switch anything?
It would work, but the quality of the video over a single component or video cable (basically just a composite RCA cable) would be pretty poor compared to using HDMI. I watch HD and digital cable while listening to CDs and that would look really bad over a single composite video cable.
post #2914 of 4921
Originally Posted by Legairre View Post
It would work, but the quality of the video over a single component or video cable (basically just an RCA cable) would be pretty poor compared to using HDMI.
Legairre, I think it's about time you re-post your XBR4 settings in the calibration thread. Dudes are posting some seriously hurting settings in that thread these days. Mine is 99% true to yours and I haven't been in the picture menu for months (my girlfriend thanks you too!).
post #2915 of 4921
You should have a setup menu on your TV during the MCACC process that shows every step MCACC is going through not just on the 94 display.
Here's a few of the screens you should see:
Attachment 109702
Attachment 109703
Attachment 109705
Do you have HDMI control turned on or off? Also just for the fun of it can you hook up a single RCA cable to the 94 MONOTOR OUT and run it to your TV. Make sure your on the right TV input too and that should at least give you a screen so you can see things and start to resolve the issue. Monitor out always outputs a signal no matter what happens.
Here's a pic of where monitor out is on the 94. It's the one with the bent arrow pointing to it.
Attachment 109706
post #2916 of 4921
I don't think it was me with the XBR4 settings, because I don't have a Sony TV. I bet it was someone with a name similar to mine that made you think it was me.
post #2917 of 4921
I set up mine the same way with just the HDMI cable from the receiver out to my Pioneer Plasma. The only other thing you must do is turn the TV on and select the HDMI input you connected the receiver to, turn on the receiver then push the button marked receiver on the remote, then push the setup button on the remote and in a few seconds the setup menu appears on the TV screen.
post #2918 of 4921
Is there any kind of volume limiter in VSX94? You know, to kill the (*&#^%$ yelling commercials...
post #2919 of 4921
No, I think the new 1018 has that new feature.
post #2920 of 4921
That's why I also mentioned component cables. It's been argued that there's relatively no differencve between them and HDMI and if any difference , very slight.
post #2921 of 4921
Ah now I understand. That would work and then you'd just have to switch the input on the TV to the component input vs. leaving it on the HDMI input. I've tried component and HDMI on my Mitsu HC1500 projector, but HDMI has much better colors. Also things with component are washed out and the picture isn't as sharp compared to HDMI. That'sj ust my setup yours may be different.
post #2922 of 4921
Originally Posted by wingnutdad620 View Post
I'd be curious to know the answer as well. I'd like to move my CD's to an external USB hard drive so as to not have to load/change CD's all of the time.
Rip them in FLAC and you wont have a problem. I believe the previous posters problem is that his tracks are in Apple lossless. The 94 doesn't recognize those. It does however recognize FLAC which is a lossless compression.
post #2923 of 4921
You have helped me with advice before...Now I have a real stumper for you...
I just got the DVE essentials HD DVD and Blu Ray discs and wanted to re-calibrate my theater with them and the 94...
Problem...Every time I push the set up button the receiver guess what...It cuts off the HD or Blu inputs and I can't do anything...
Any advice on a workaround? Can the OCD be disabled temporairly? Help!
post #2924 of 4921
Are you just trying to adjust the speaker levels with the DVE test tones?
post #2925 of 4921
Yeah, I would like to...What do you think?
post #2926 of 4921
^^ There is a way via remote, posted somewhere in this or the 92 thread but I cannot remember the exact post/er.
post #2927 of 4921
The 94 works the way most receivers do if you go into setup, the OSD shuts off any other display. Unless I'm misunderstanding you all you need to do is hit the CH LEVEL button on the remote, and then use the VOL +/- to increase or decrease the channel level while you run the test tones from DVE. The channel level will be displayed on the 94 display and you can keep the DVE display on your TV monitor.
post #2928 of 4921
^^ Yes, that's it.
post #2929 of 4921
Hey emptychair how the heck have you been?
post #2930 of 4921
damn i wish I knew where it is...thanks though
post #2931 of 4921
ok, so I can navigate through each channel individually? And...those settings will be saved? cool if yes...
post #2932 of 4921
Thanks legairre. In my head it made sense that it could work that way but thought maybe I was missing out on something. With my Pioneer plasma HDMI might give a little better picture, but nothing that really jumps out and says it's definitely better. Might be my mind adjusting my eyes, lol.
post #2933 of 4921
It "0" on the remote. Just make sure you hit "receiver" on the top of the remote first. Now that I think of it did you mean you wish you knew where you put the remote or where the CH LEVEL is on the remote?
post #2934 of 4921
Thats it you got it. They will definately be saved.
post #2935 of 4921
Doing well thanks! Haven't had as much time as I'd like to spend here, but always catch up when I can. The time & effort you put in to support everyone here is mind boggling.
See you around
post #2936 of 4921
Thanks a million...Man, the nitwits at Pioneer said it could not be done. Duh.
post #2937 of 4921
Ok, just to be sure, on the remote, how do I navigate through each channel though, doh?
post #2938 of 4921
See you around
Good to see you again. It's really not that much time, I just dart in and out every now and then.
post #2939 of 4921
Just keep hitting ch level. Everytime you press ch level, you get the next channel. It will cycle through all the available channels.
post #2940 of 4921
Thanks, Legairre, I figured it had to appear on the TV for the manual says to turn on your TV and besides I don't see how those menus could appear on the 94's display. I haven't turned on the HDMI control because I seldom need the 94's sound processing just when I watch regular TV. I checked all the TV's HDMIs just in case one was misconnected, but still nothing appears on the TV screen. I guess I could switch on the HDMI control, if that is imperative, just for the MCACC calibration. I'll give it a try. Thanks again.
