Originally Posted by
acid_bath2
ok guys I'm kind of a noob and need some more assistance with my 94.
I read the instruction manual and it didn't seem to help much.
I have a PS3 hooked up to HDMI port 1 and have the audio set to PCM.
I was flipping through the sound options with the THX button on the remote and the best I can get is PL II+MV THX. THX Cinema 1 or 2 are not available as an option for some reason.
Is there a setting i missed perhaps?
Any help would be greatly appriciated.
See page 29 of your manual. The first time you push the "THX" button, you should get "THX Cinema". Repeated pushes cycle through the other selections (the second push gets you the "PL II MV+THX"), etc. The 4th push should get you "THX Select 2 Cinema", three more pushes will get you back to "THX Cinema".
Since you are using the LPCM coding out of your PS3, the 94's display will not show that you are decoding TrueHD or DTS-HD Master Audio (that only happens when you use bitstreamed audio -- the PS3 only outputs the HD audio tracks via LPCM).
As
Legairre asked, what does the 94's panel display when you do select THX Cinema (the 1st push of the button)?
Stechs01 -- As I mentioned, the PS3
only outputs HD audio via LPCM. PS3 bitstreaming only outputs the core DD or DTS audio (if anything - I don't have a PS3 either, just reporting what the PS3 threads say).
