AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony XBR4/XBR5 calibration thread
Official Sony XBR4/XBR5 calibration thread - Page 73
post #2161 of 5489
Originally Posted by bpade View Post
I just used your spreadsheet to calibrate mine last night. The improvement was dramatic. I'm far from an expert, but some of the greens looked a little too green. Has anyone else used these settings and thought that?
Overall I'm very happy with these settings.
+1, I'm really pleased with darkdune's custom settings. However, I have also noticed the excessive levels of green. If you can find a way to minimize this, please post your findings.
BTW, thanks, darkdune, for taking time to post your settings.
post #2162 of 5489
I know I am a little late to jump in on this, but having finally purchased a 40XBR4 (and my first LCD at that!) I used bpmurr's settings, and they look phenomenal. Thanks everyone!
post #2163 of 5489
Hey,
Glad to hear it. Do you mostly have upconverted Standard DVD for source material, or are you seeing good results with Blu-ray or HD-DVD too?
You may be slightly right about the Green. One movie I can think of as an example is Monsters, Inc. from Pixar. Mike Wazowski (Billy Crystal) looks a little too much like a "booger", but maybe that was the film-maker's intent ...
If you dial the color down a little bit, the Green may look a little more appropriate. You can also dial the G-Gain and G-Bias down a bit to see if it looks more to your liking.
post #2164 of 5489
i just traded in my 71 for this xb4r, ran through a bunch of calibrations. but i still cant see it as having better PQ than the 71, i am not bashing this tv at all. maybe its just my personal preference...i am trying to like this tv...it just seems to have a lot more motion blur and smearing and grainy areas than the 71....ughhhh i'm stumped
post #2165 of 5489
Thanks, they tend to please those who aren't into the D65 look. I'm always adjusting my set because I find a lot of the times its content dependant. More so on cable shows then games or movies.
post #2166 of 5489
You're very welcome!
I figure when ya spend as many bucks as we did (even with all those awesome payment plans, and discounts this past Holiday Season), and Sony gives you features and options...there should be a reason for it, right?
From my "upconverted Standard DVD" experience, it seems that the features many posts here have discouraged we employ actually make the upconverted Standard DVD stuff look better on these TVs. That is what I am seeing, and my gut says perhaps that was Sony's intent for these options. We all have a ton of DVD's already, and the upconversion process inherently adds image distortion by the "physics" of the process.
I am hoping for Blu-ray and HD-DVD that the enhancement features will no longer be needed for viewing that source material. Hey, thank God Sony gave us enough inputs! Each one can be calibrated to use. HDMI for upconverted DVD can be totally different from HDMI for Blu-ray or HD-DVD. Cool huh?
For Green, here is what I just posted a second ago again:
I will probably return to Irstevens421's settings when we get a PS3 next X-mas. Much thanks to him for helping us all!
post #2167 of 5489
I agree - so far I've been watching mostly HD, but I am going to have to tweak it a little bit for SD, I think.
post #2168 of 5489
Hey,
I was watching Discovery HD via DirecTV and The Patriot on upconverted DVD.
My Blu Ray/HD DVD player arrives today.
I want to repeat that your settings made a big improvement, and I really appreciate it. I'll try your green tweaks tonight.
post #2169 of 5489
Hey,
where is this spread sheet everyone is talking about?
post #2170 of 5489
http://www.avsforum.com/avs-vb/showp...postcount=2102
post #2171 of 5489
What's the D65 look?
post #2172 of 5489
D6500, the gold standard for accurate grayscale and color temperature.
post #2173 of 5489
Your settings are based on this right? Thanks again for posting your settings, I have them as my Custom settings (Warm 1, though) and on Standard I have my settings which are similar to bpmurr's. Depending on what I'm watching I switch between the two, since the result is so different it's almost like having two TV's. I have to use my own settings for 360 since I use the VGA & PC input and the colors are very different compared to 360 via component. Eventually I'll get a PS3 and I'm looking forward to trying your settings with that and Blueray.
post #2174 of 5489
That's correct, although your results may not be the same as mine, it should serve as a good starting point.
post #2175 of 5489
HEY MUSCLERUNT
I did ur calibrations for my 40 xbr4 and i noticed that u put MODE 1, but when u activate that, the mode 1 itself is on zero for both reality and clarity. What numbers/configuration do i put the Reality & Clarity to?
Anyone helping would be appreciated Thanks
post #2176 of 5489
Originally Posted by ReggaetonSalsero View Post
HEY MUSCLERUNT
I've experimented extensively with DRC and find 40/60 gives the best result.
A_C
post #2177 of 5489
Originally Posted by R.MnTnA View Post
Well since my cable is going directly into my TV which also picks up HD and SD, I just leave it on Low. I don't think you can see much difference in HD, at least I can't.
I tried all of the settings here including the cnet for my 40 xbr4. I found R.mntna to be one of the best BUT i took off turned off the the Live Color and put the Color Space to Standard and found the picture to look Much more natural looking and it doesn't have the slighlty reddish/pinkish/brightest push to it. But this is just my preference for OTA cable & for the Cable box. I have TWC. I put motion enh. to high and auto1 on since i didn't notice much difference with the auto2. With standard, u just don't get the that 3d feel like u do with motion enh. on high. I put the auto1 on with it because the manual clearly let's u know that auto 2 with CANCEL OUT the Motion enhancer so it's like u have it off so what is the point.
Also, the motion enhancer/auto1/2, 120hz, all that technology is not even going to work 100% of the time accurately anyway so u just need to get used to seeing a bit of judder here and there. If u read up about it u will find info stating this. But when it works, it looks nice
Hope this helps someone
My only issue is with the DRC palette and i can't find anything for the xbr4 showing what to put the reality and clarity on when i had Muscle's calibration.
post #2178 of 5489
A_C
40/60 meaning 40 reality and 60 clarity or the otherway? Also, u used this with Muscle's calibration or someone elses? Thanks
post #2179 of 5489
Maybe I should expirement with this feature. Sounds pretty cool .
post #2180 of 5489
GO for it and let us all know ur take on it
post #2181 of 5489
Well I finally hooked up my new 46XBR5 and she's ugly..on regular satellite, guess I'll have to upgrade my satellite receiver to HD but being in Canada it doesn't appear Bell has receivers with HDMI which seems bizarre to me, fellow canucks can chime in on this as I haven't been to the store to check.
Hooked up the standard DVD player through components and thought the picture was amazing but a little too amazing..sure enough I didn't realize I had to apply separate settings on each input, it was on Vivid. I went with darkdune's cinema setting with a few tweaks from larone's and I think the picture is superb for SD DVD. Thanks guys for your contributions. I did get frame stutters with my test DVD (War of the Worlds) but when I reduced motion enhancer from High to Standard it seemed to help a great deal.
Oh by the way did I tell you I love this TV!
post #2182 of 5489
im wondering what the best settings are for xbox 360 and for playing halo 3 i will be getting the 52xb4 soon so i want to know the best customization
post #2183 of 5489
i was just wondering is there a Sony TV setup Picture Thread for TVs like the XBR2/3/4/5 and the W/V seies.
post #2184 of 5489
If you love this tv with standard def, you are in for a real suprise when you find some HD content.
post #2185 of 5489
Yep.
post #2186 of 5489
Thanks, DD. I'll give the recommendation a shot tonight and report back.
post #2187 of 5489
Any update on firmware ?
post #2188 of 5489
Sounds like you have a case of the "overcompressed cable blues". Honestly there's probably no real fix for this, most cable companies compress high definition to within an inch of its life. Compression effects fine detail, sharpness of the image, picture noise, color reproduction and shadow detail. This is why your Bluray movies look MUCH better than what the cable company is pumping out. Fios is the only cable provider that I've seen who deliver a crisp cable hi-def experience (no I don't work for verizon ).
BTW, it's not surprising that the 42" 720p Samsung looked better with a cable broadcast, a larger screen and more lines of resolution will amplify picture/source imperfections.
Larone
could u plz post u settings again ! i cant find it
post #2189 of 5489
I can't tell you how many PM's I have with this question . I think I should just post them every couple of pages. Maybe we can reach out to the Op or Mods and get the favorite settings posted on the first page.
post #2190 of 5489
Here ya go (you're right, they are hard to find).
Power Save Mode: Off
HDMI - 1080p24 (1080p24 Blu-ray/HD-DVD & PS3)
Mode: Custom
Backlight: 4
Picture: 95
Brightness: 50
Color: 58-62 (Only with 1080p24 sources)
Hue: 0 - Middle
Sharpness: 30
Color Temp: Warm 2
Noise Reduction: Off
Mpeg Noise Reduction: Off
DRC: Off
Black Corrector: Off
ACE: Off
Gamma: Off
Clear White: Off
Color Space: Standard
Live Color: Off
White Balance:
Red Gain: -1
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -3
Blue Bias: 0
Detail Enhancer: Low
Edge Enhancer: Off
Motion Enhancer:
Cinemotion: Auto1
Video Color Space (x.v.color): Auto
Color Matrix: Auto
Game/Text: Off
Light Sensor: Off
Display Area: Full Pixel
HDMI - 1080i60 & 1080p60 (Cable, Satellite, Xbox 360 & Non 1080p24 Hi-Def Players)
Mode: Custom
Backlight: 3
Picture: 95
Brightness: 52
Color: 55
Hue: 0 - Middle
Sharpness: 30
Color Temp: Warm 2
Noise Reduction: Off (Low for Cable/Satellite)
DRC: Off
ACE: Off
Gamma: Off
Clear White: Off
Live Color: Off
White Balance:
Red Gain: -1
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -3
Blue Bias: 0
Edge Enhancer: Off
Motion Enhancer: Off / Standard (Personal Preference)
Cinemotion: Auto1
Color Matrix: Auto
Game/Text: Off
Light Sensor: Off
Component Video Sources - 1080i
Mode: Custom
Backlight: 3
Picture: 94
Brightness: 40
Color: 52
Hue: 0 - Middle
Sharpness: 50
Color Temp: Warm 2
DRC: Off
ACE: Off
Gamma: Off
Clear White: Off
Live Color: Off
White Balance:
Red Gain: 0
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -2
Blue Bias: 0
Edge Enhancer: Off
Motion Enhancer: Off / Standard (Personal preference) - Mines is off
Cinemotion: Auto1
Color Matrix: Auto
Game/Text: Off
Light Sensor: Off
Display Area: Full
Component Video Sources - 1080p (Component Xbox 360)
Mode: Custom
Backlight: 4
Picture: 100
Brightness: 40
Color: 54
Hue: 0 - Middle
Sharpness: 50
Color Temp: Warm 2
DRC: Off
ACE: Low (Acceptable for Video Game Sources)
Gamma: Off
Clear White: Off
Live Color: Off
White Balance:
Red Gain: 0
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -2
Blue Bias: 0
Edge Enhancer: Off
Motion Enhancer: Standard (Personal Preference)
Cinemotion: Auto1
Color Matrix: Auto
Game/Text: On
Light Sensor: Off
Display Area: Full
YMMV
