Dear fellow XBR owners,
I am not much of aficionado or professional when it comes to t.v.'s and what the settings do, I just "flip back and forth left to right" and try to pinpoint the difference that some of the settings, to me, do to the picture. I've also read most of the post on the 71f and xbr4 as well as the 81f from the "ownership" to "vs" forum.
Blu-ray feed I run through an hdmi cable on my ps3, Dvd is also up-converted through my ps3. Hd channels i receive through an hdmi feed from my comcast hd/dvr box.
I've owned a 40" Sony S2000, sold it. I've owned a 32" samsung lns3241d, sold that; i've also owned the model before the 41d as well. Ive owned a 46xbr2, sold that. (not in that order) And now im a proud owner of a sony xbr4.
I just love this t.v. I've spent countless hours and gasoline visiting C.C., B.B., and other retail stores trying to compare the new breed of lcd's. And i have seen the rest and i declare the XBR the best lcd, but i do like the 71f also. I've owned this 46xbr4 for the past two weeks and since the very first day i have spent countless hours tweaking the picture, day in and day out trying to find that right balance of darks, grays, colors, and sharp picture.
This is what i have discovered about the xbr4.
"brightness" helps bring out the details with'in the blacks (if you want more contrast/detail in dark areas of the picture/movies etc. a 54+ setting is recommended)
"Noise" kind of blends/blurs the picture to give the picture a more smoother feel (my settings are always off/low this way it offers a crisper picture, whats the point of hi-def if its not "hi-def."
"mpeg" is similar to noise, but i'm not quit to sure about this setting..so yea. (this option i usually leave off, to me it kind of distorts the picture. How? i dont know, sorry)
"Drc Mode" is similar to the "detail" option or the "detail enhancer option" the higher the mode (mode 1, mode 2) the more detailed the picture quality becomes. This setting isnt good for jsut any feed. ("Mode 1" i suggest for 1080i cable/satellite, but if you have a good signal "mode 2" might work as well, but i usually just use it for video games.}
"Drc Pallet" is a very important function on the xbr4. Some people might not notice how this function affects the picture but it does tremendously. There is a "Reality" adjustment option as well as a "clarity" adjustment option. If you freeze frame a picture of a well lit face in a movie (matrix 3 when neo wakes up in the train station with the little girl above him) when you bring the reality option up past 55 you will notice more "pronunciation/detail" in Neo's face. But if you movie the clarity bar the the far right, the picture comes a little smoother. (adjust the image the way you see fit)
"Black Corrector" just makes "blacks" more black.
Advance "C.E." this option will emphasizes the position of the shadow that surrounds an object. It can make an object pop out more by over shadowing the picture ex: a circle, the more you shadow it with pencil the more it will look like a ball. (apply this to the face of the little girl that wakes neo up in the train station)
"Detail Enhancer" this option does like it sounds, it enhances the detail of the picture, but if you over do it on certain images it might distort the lines causing it to have a "vertical" affect. (Remember your t.v is a "high-def" tv so why turn it off all the way)
"Edge Enhancer" This option is also not to noticeable but on certain thin lines you will see the extra thickness it cakes on to the line. (this was also mentioned on sharpjunkies forum page)
"Motion Enhancer" and "CineMotion". Now this is almost like the 71f low/med/high.
(71f/off---xbr/
M.E.off/C.M.off,)
(71f/low---xbr/M.E.standard/C.M.off)
(71f/med---xbr/M.E.standard/C.M.auto1 or
M.E.high/C.M.Auto2)
(71f/high---xbr/
M.E.High/C.M.auto1)
The other x.v. and so forth options i have not touched yet.
Well anyways thats just the basics from MY perspective. see how it suits you when you calibrate your xbr4 to its max potential. And here are my settings for Comcast HD and Blu-Ray
1080i Comcast cable feed (HDMI)
Picture Mode: Cinema
Backlight: 7
Picture: 72
Brightness: 59
Color: 56
Hue: 0
Color temp: Warm 1
Sharpness: 90
Noise reduction: off
MPEG noise reduction: off
DRC mode: Mode 1
DRC Pallet: 60/85, 50/60
Advanced Settings
Black corrector: Off
Advanced C.E: low
Gamma: high
Clear white: Off
Color space: Standard
Live color: Off
Detail enhancer: med
Edge enhancer: low
Blu_Ray(HDMI)
Picture Mode: cinema
Backlight: 8
Picture: 78
Brightness: 68
Color: 49
Hue: 0
Color temp: Warm 1
Sharpness: does'nt matter for blu ray
DRC mode: off
Advanced Settings
Black corrector: low
Advanced C.E: med
Gamma: med
Clear white: Off
Live color: Off
Edge enhancer: low
White Balance Menu/ defualt
Screen menu
Wide Mode: Wide Zoom
Auto Wide: On
4:3 Default: auto
Display Area: Full Pixel
Video Options menu
Motion Enhancer: Standard/high
CineMotion: Auto 1
Game/Text mode: Off
Video/Photo Optimizer: Video
Video Color Space: default
Photo Color Space: defai;t
Color Matrix: Default
RGB Dynamic Range: default
