AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung LNT-xx71f Owners Thread
Official Samsung LNT-xx71f Owners Thread - Page 503
post #15061 of 28843
Originally Posted by Gweedo08 View Post
I'm using a mixture of settings and my wife likes dynamic where the colors are very vibrant. I am using settings in standard mode and while everything looks pretty nice, it could stand to be a bit more vibrant and 'wow'. Any suggestions? I don't want to use straight dynamic because I feel the colors bleed a bit to much. Thanks in advance.
To add more WOW, up your contrast, as well as your dynamic contrast. Bump up your color. I believe Dynamic comes with AMP as a default setting, so put standard to AMP=low. Make sure your Color Space is set to Wide. Bump up your backlight if you want it brighter.
post #15062 of 28843
Originally Posted by RawisTheGameHhH View Post
For those wondering if firmware 2004 will help your QAM turner to actually pick up those free HD channels; the answer (in my case) is NO
Tonight I can report the same for me as well.
I called Samsung and got the 2004 firmware. Upgraded it and then scanned. I gained two channels but not the one I want. I got a test channel with an oscilliscope screen and HDNET (which I have on DirecTV already).
post #15063 of 28843
Originally Posted by maser View Post
Have searched this thread and clicked on just about every link on Samsungs web site and can't determine whether the 4671f is a 8 or 10 bit panel. It is listed as "10 bit processor", but I would imagine that this refers to the digital processing as opposed to the bit depth (color gaduations) of the panel itself. The description of the 65f series on the Samsung web site states "... 1,064 graduations of color ..", (which I presume is a 10 bit panel), however this same statement is missing from the description of the 71 series. Hard to believe that the newer, "more advanced" 71 series is not 10 bit, however it's a bit suspicious that Samsung is mute about the panel bit depth on the 71.
Does anyone know if the 71f panels are 10 bit?
Question is whether the processor is sending out 10bit/color to the pixels, even if the panel is listed as "10-bit".
The 65 series initially were shipped with "10-bit" panels. Now they appear to be shipped with "8-bit" panels. No one complains that the PQ has suffered. The UK equivalent of the 71 series is now shipped with "8-bit" panels. The flagship LCD from Samsung, the 81 series, is shipped with "8-bit" panels. The 71 series is shipped with "10-bit" panels. The description of 10-bit or 8-bit is based on what we found on various Samsung parts sites.
Samsung never advertises 10-bit color depth. Sony prominently advertises that their sets have 10-bit color depth.
If you are an optimistic owner, you'll believe that the 71 series has 10-bit color depth.
post #15064 of 28843
QUICK QUESTION...
For those who own the Samsung 40" (LNT4071F) LCD HDTV..
-Does anyone have an actually screen picture of how the quality looks?
-Has anyone experience any problems with them?
-How do sports such as Basketball & Football look on this TV?
-Is the extended warranty worth buying?
-Is the LNT4065F any different than the LNT4071F?
Thanx in advance
post #15065 of 28843
Originally Posted by rousemc View Post
Well, I finally found out that I can't upconvert DVDs with my Xbox ELITE with AMP on without stutter. It is so odd that the 4671 with 10--x FW does not get along with the Xbox 360 where the 4671 with 200- FW apparently does. I can watch HD content with my HD-DVD add-on and upcovert DVDs with AMP OFF with very little to no stutter, but turn it on and BAM...STUTTER CITY! I realize this has been said before, but I can't get around it. I really need to call Samsung today and ask why previous TV didn't have problems with this. Had I not had dead pixels on my previous television and returned it, I would likely be pretty happy as I would have stuck with my 4671 2002. Also, it amazes me that I get a TV apparently built around August with FW 1007 shipped out at the end of December 2007. Sigh.....I really hate the idea of returning this TV. SAMSUNG TECHS PLEASE HELP!!!
You having owned both the sets and seeing the difference makes you the second to say this exact thing. This is confirming the results we have seen in the spread sheet for some time. It would be great if you contact Samsung and tell them your experience so they can start down the right path.
Regard
post #15066 of 28843
Originally Posted by splattered View Post
E...... I've been meaning to replace it, but the outlet i'm using had the bottom section painted over so i'm using the top section with a surge protector, and then another surge protector plugged into that one hahaha (tho the tv is in the surge protector that goes to the wall, not to the other surge protector)
I just installed a whole house surge protector in my breaker box. It snaps in in place of 2 breakers and cost about 70 Dollars. It was very easy to install, and now my whole house is protected. I am also installing a surge protector on my coax line. I'll probably plug the tv into a surge protection strip just to be sure, but I am pretty confident in the whole house approach. You just need to check it every once in a while to see that the lights are on it. When the lights don't work, you know it took a hit and did it's job.
Anyone else have any experience with the whole house surge protectors? They are much cheaper than the multi-tap plug in units...
post #15067 of 28843
I have mine set to auto and it kicks it out at 24p, so i dunno...
So in other words, you can hit info on the Samsung xx71 button when you have the PS3 as a source and you see 1080/24Hz coming in???
If so, is this just for BR or STD DVDs as well?
post #15068 of 28843
Regard
HERE !!! HERE !!!
BTW - Shayne, where do you live in Canada.. Man it is going to be getting BRUTAL cold this WKD man!!!! The NFL NFC game Sunday 5:30pm will be in Green Bay and it is supposed to be a high of 5 degrees.
Have to test for the FROZEN stutter and TBE ....
post #15069 of 28843
Thanks. I will check it out. As far as the 'mini-blinds' effect, does this happen during fast paced sequences? I have been noticing strange lines and boxes when people move their arms around or graphics go fast on the screen. I have fw 2004
post #15070 of 28843
I read that a lot of people are having problems with the LNT4071 when it comes to watching HD DVD/Blu Ray Movies. Apparently Auto Motion Plus blurs like crazy.
post #15071 of 28843
Originally Posted by onund View Post
I can't tell you what to believe, that's your choice. The only objection I have at this point is if you say it's known fact that the core FRC IC has changed between the two sets.
Originally Posted by petrovy View Post
Well, that pretty much confirms what we thought: new FRC board by Micronas necessitated a new fw2k.
and
I cannot tell from wiring diagrams weather the indicated FRCM schematics is for the newer Micronas board or for the aforementioned sub-FRC. HOWEVER, and I reiterate the SM specifically states: "*FRCM: Micronas FRC Board- Peony model has two different FRC board, one is Samsung FRC IC (basic model) the other is Micronas FRC IC(derivative model)".
Originally Posted by Kath37 View Post
My source at Samsung informed me that there are 2 different versions of the 71 our there.. one that uses the 10xx f/w and one that uses the 20xx f/w.
and
this is a board difference.. Not a panel .. turns out the 10xx board was made by one manufacture which stopped making the boards for this set. Then they switched manufacture of the board and changed the 4 digit version number on the side of the TV.. Samsung is assuring there is "no difference" between the boards but i mean if it was a different manufacture i guess that is possible.. This actually isn't the main board that is different either it is something called the FRC board that has changed.. so video processing has not changed a bit. (that is all through the main board)
Thats what we are saying. Why would you have an objection to that? Kath37 straight from samsung states it was the FRC board. Petrovy service manual states there is two difeerent FRC boards. You agree that there needs to be a hardware change to require a completely different firmware. These are found in two different folders poney and peonym (micronas). What do you believe has changed. I also believe it can be stated with fact that the 2000 tv stutter less than the 1000. The amount of data and feed back on this forum has confirmed that. Youknowryan agrees that 2000's stutter less and for a short time changed his signature to 2000 stutter but less. I really think samsung would not like us to draw these conclusions but i do not care if the have any objections either.
Regards
post #15072 of 28843
Here is my online chat with the Samsung guy:
Please wait for a Samsung Agent to respond.
You are now chatting with 'Asher R'
Asher R: Hello, I am a Samsung HDTV LiveChat representative. How may I assist you today?
Brian : Hi, I'm curious if there is any update to the TBE problem and stutter problem the 71 series panels are having?
Asher R: Let me know the model number of your TV?
Brian: lnt5271f
Asher R: Thank you for the information.
Asher R: The firmware fixes TBE when Auto Motion Plus (AMP) is set to Off and Low. It also makes TBE about 50% better when AMP is set to Medium but did not do anything for the AMP high setting.
Brian : are they still working on a fix for the medium and high setting?
Brian : also, what FW number are you talking about?
Asher R: Yes, it will work if set to medium, but did not do anything for the AMP high setting.
Brian : I have 2 other pretty major issues with the set, 1 is the stuttering on some channels, it looks like the picture is moving a a frame per second sometimes
Brian : the other is on 1080i on hdmi1, when there are quick scene changes, it looks like there are 5 mini blinds cutting across the screen, this ONLY happens on 1080i sources and ONLY od hdmi 1, not 2 or 3
Asher R: Thank you for waiting. I'll be with you in just a moment.
Brian : ok
Asher R: As of right now STUDDER will not happen at all with AMP OFF.
Brian : correct, but I use AMP a lot when watching sports, the 120hz amp features are the main reason why I paid the extra money for the tv, I certainly don't want to have to leave them off all the time
Asher R: We have not figured out if this issue is source related or TV related yet so we can not guarantee a firmware update for stutter.
Asher R: We are looking into it and if a firmware or Hardware fix becomes available we will contact you to inform.
Brian : do you know why I would have the mini blind defects mentioned above on HDMI1 and nor 2 or 3
Asher R: I'm sorry for the delay. I'll be right with you.
Brian : k
Asher R: Our engineers are working stutter issue, once any update is available, we will contact you.
Brian : the defect with the mini blind effect flashing between scenes is seperate from the stutter issue, I have been troubleshooting it and noticed it only happens on hdmi port 1 when broadcasting a 1080i signal. ports 2 and 3 do not have the defect
Asher R: Let me know, does the screen gets dark?
Brian : no, just the middle of the screen gets about 5 lines across horizontal very quickly as the scene will change from one camera to another
Asher R: Okay, I understand your concern.
Asher R: If it happens on source, then there is no problem with the TV and its and issue with the sourece.
Brian : it would be the tv if the problem only shows up on HDMI port 1 and not in 2 or 3 with the same source
Asher R: Then try to connect another input source to check like a dvd player.
Brian : did, it happens when my dvd upscales to 1080i on port1
Brian : it seems like an interlacing issue only on hdmi1
Asher R: If the issues persists on all sources, then your TV needs to be serviced.
Brian : how do I go about getting a tech out to swap a board or whatever they may do?
Asher R: You can start by filling out one of these online service request forums that I will send over to you.
Asher R: http://www.samsung.com/us/support/re...viceRequest.do
Asher R: After that a service center will just contact you in 24-48 hours to arrange for a good time to come out there and inspect/fix the TV.
Brian : ok, thank you
Asher R: You are welcome. Is there anything else?
Brian : nope, thanks for all the info
Asher R: Thank you for contacting Samsung Technical Support. Please click on 'Close' button to end the chat session and take few minutes to fill in the Customer Survey Form. Your feedback is greatly appreciated
post #15073 of 28843
Originally Posted by ACEdubs View Post
46" 71F
Already searched.
Anyone else have very small lines that run top to bottom, on eitheir side of your screen. Tiny..maybe 2 pixels. They run perfectly straight up and down.
I noticed them when watching a Blu-Ray today.
Originally Posted by kjgarrison View Post
No.
I attached 2 pics of either side of my screen. You'll see the black lines I'm talking about. Maybe its normal....dunno
Makes me feel like I bought a 45.97" screen.
post #15074 of 28843
Originally Posted by clau View Post
Not really, but don't want to argue with you anymore...
Note to myself: Never argue with anyone who believes majority wins.
That was not meant to argue but to explain what you said is a mystery to you.
But you're right, it's difficult to discuss matter with a closed mind. It's best we let it be.
post #15075 of 28843
Originally Posted by cybolt View Post
Mr. Mini-Blinds here with my brand new replacement 4671, which I brought home Wednesday night. PC serial, 2003.2 fw, 1001 hw. Plugged my DTV hr20-100 HD-DVR into HDMI 1, played an episode of Monk recorded from USAHD and voila! Mini Blinds! Again! In exactly the same place on the screen--about 1/3 from top! Here's the deal: 99.8% of them are in the commercials (again)! The program is shown in 1080i full screen, no pillar boxes. The commercials, according to my hr20 are also 1080i but with pillar boxes, put in by USA, not by my box. Some of the commercials, such as KFC and a promo for Psych run more than once in an episode and the mini-blinds appear in exactly the same spots. Played another episode of Monk and mini-blinds again, in the same spots of the same commercials. At this moment, watching a live version of Monk, saw KFC commercial and.you know it, more blinds! The kicker is, once again I plugged into HDMI 2 and nothing! No Mini-blinds anywhere! Therefore, I don't believe this is an AMP issue or STB issue.
As suggested, I removed all other HDMI inputs, just the one from box to TV. Can it be possible that HDMI Port 1 cannot deinterlace properly, but 2 and 3 can? Since its always occurring in the same places of the same commercials with pillar boxes, could it be some issue with USAHD and them bumping commercials to 1080i?
Remember, this is my second 4671 with exactly the same issue so its hard for me to believe that I would get a second one that has the same, rather uncommon problem.
Request: Will everyone with this set and DTV HR20 please record Monk on USAHD (242) and see what they get with DTV going to HDMI 1? I have another 30 days to rectify. Get a Samsung Tech here? (Larry the Samsung Dude is THE funniest image I can imagine!).
I swear I'm not the AntiChrist but.. I have a BB one mile away, they have 2 Pio 5080s (one dollar less than this past millennium), saw it yesterday (stunning) and am tempted to bring it in and run side-by-side. Solutions first, please.
Remember: Ignorance is simply a lack of information or knowledge.
I'm debating calling in a service call for this too, Not sure exactly what they would do, even replacing the board may not fix it being that you just replaced the whole tv and still have the issue. What do you guys think?
post #15076 of 28843
All this talking about Motion Blurr & TBE and having to make firm upgrades makes me not buy the Samsung LNT4071 and go with the Sharp Aquos 42" with the free Blu Ray player. I used to own a Toshiba 37" 720p and not once noticed a problem, and Samsung has all these problems.
post #15077 of 28843
Originally Posted by carrera1 View Post
I am here because I am able to glean valuable information when sorting through the posts. Also,. there are 2 sides to every story. I have bigger fish to fry than having some hidden agenda with this set or any other consumer product. Yes, I agree that having the 200x firmware helps.
I apologize for the agenda crack and i am sorry. You have every right to be here like the rest of us. You must understand that the problems that you do not have on your set may exist for others.
Regards
post #15078 of 28843
Originally Posted by neonflx View Post
i give up on this thing, i tried for two days to get what firmware i have and no matter what i do, it does not show it
my set is dec 07 , taking it back
To check your firmware version, here are the instructions:
1. Turn on your TV.
2. Press the MENU button on your remote.
3. Select SETUP, and then press ENTER.
4. Select Function Help, and then press ENTER.
5. Use the Up or Down arrow button on your remote to move down to Function Help to ON, and then press the ENTER button.
6. With Function Help ON highlighted (don't actually push ENTER on it), press the INFO button on the remote. Your firmware revision will be listed as two lines of information. The TOP line is your software firmware. The BOTTOM line is the hardware revision number.
You are probably not doing step 6 correctly. That's where a lot of users mess up.
Add step 5.5
5.5 Go back into the Help menu and move the pointer to the "ON" field so that it is highlighted/glowing.
6. Then press the "INFO" button on the remote.
The important part is to press Info while the On option is hightlighted under Function Help. Do not press enter while highlighting On as this will make the menu dissappear. Press Info and underneath the Menu box a smaller box will appear after a brief moment and list your software and motherboard.
Regards
post #15079 of 28843
You guys arent being helpful at all at not answeing my questions, that sucks I want to know what is the best firmware for the LNT-4071 and if its worth the buy or should I got with the LNT-4065F?
post #15080 of 28843
I would go for the 4071, this set has an amazing PQ and if you order from Amazon, it sounds like you would have a good chance at getting a 2xxx FRC model.
Even with AMP=OFF, the 4071 will outshine the 4065 in PQ.
As far as TBE, if you do get a 2xxx model, you can update the FW to 2004 and with this FW, there is no TBE when AMP=LO and very little on AMP=MED.
Go with the 4071..
post #15081 of 28843
Go with the 4071..
Thank you for all the valuable information and for answering my question. At first I was looking to buy the Sharp 42" Aquos with Free Blu Ray DVD but hopefully I can get this TV and be satisfied with it. By the way, which one is the 2xxx model?
post #15082 of 28843
any info?
post #15083 of 28843
Damned Miniblinds/Scanlines My 4671 had no lines (1xxx firmware series). This 5271 2xxx firmware series has this mini blinds/ scanline problems. I noticed using a pc on all hdmi inputs and ps3. It was there. I then left the pc on hdmi1 and then renamed that input and voila. It went away, but when I did the same to hdmi2 it did not go away either with the pc or ps3. A tech is being scheduled by samsung to check it out. I had the 2003 firmware first and upgraded to see if it woulda fixed it and NADA! These scan lines manifest themselves on fast moving horizontal objects usually white or bright colors.
post #15084 of 28843
I have not noticed the "miniblind" effect on my set, but now that it has been brought up, I will probably see it . This site can be a curse sometimes. Make sure that you have DNR set to off, as that can cause some motion issues. The "boxes" could be a helped with DNR off, or may continue. I sometimes get some pixelation issues with motion.
post #15085 of 28843
NO Matter what settings I change I cannot get rid of the scanlines/miniblinds, only on hdmi1 w/ a pc hooked up to it and naming it "PC"
post #15086 of 28843
lol, gotta love that 45.97" tv. I have seen something like that before, but not always. I assumed it was just the source not sending a full image in Just Scan or something.....anyway, didn't worry about it. Does it remain when you go out of Just Scan to 16:9 mode?
post #15087 of 28843
I've been reading most of the posts in this thread and I am about ready to jump in and purchase the TV. I need to purchase it online but where is the best place to purchase in hopes of getting a 2002 firmware? I've heard that Amazon is pretty good and they have a good price on the 4071F. Does anyone know where else has a good price and better chance of getting a working firmware? Thanks.
post #15088 of 28843
Chalk up another issue(scanlines/miniblinds) for this TV. This should go into the FAQ now.
post #15089 of 28843
Well that is the tricky and $1M question..
The xx71 set (40, 46, 52) have two FRC cards used in it. There is a 1xxx and 2xxx card. Samsung initially used a 1xxx card and now (I think) may use either exclusively a Micronas 2xxx FRC card (or they may be using both).
Starting in October, Samsung started integrating the 2xxx FRC card (using a 2002, 2003.2 FW) on this card.
The latest FW update for the 2xxx card is the 2004 FW.
From the vast majority of users on this thread, it seems to me that most people are very satisfied with the 2xxx (2002, 2003.2) FW, while the original 1xxx FRC card (noted w/ 1005, 1007, 1009 and latest 1013.1 FW) has more pronounced stutter. Stutter is defines as watching TV and the source slows down, then speeds up, then slows, then goes back to normal.
In the past, it was theorized that trying to get a xx71 set with a serial number of having a PA (A = October), PB (B = November) or PC (C = December) would get you a 2xxx based set..
Well this is not the case as some people (including myself) got a PB (NOV) build and ended up with a 1xxx FRC 1013.1 FW set..
The only thing you can guarentee it seems is that if you get a serial number of P9 (9 = September) or earlier, you are guarenteed to get a 1xxx based set...
So it is kind of a crap shoot on what set you will get 1xxx or 2xxx.
It seems to me that lately the LN-T5271 (52" line) when ordered from Amazon is giving the 2xxx line. I can not state that for the LN-T4071 thought..
I am not sure where you are going to buy this. If at all possible, if you are buying from a Brick and Morter store such as BB, CC, Sears, try to get a look at the serial # on the box before you get it. The Px number is a 14 or so length number (the last numbers are Px12345) or something like that..
Have fun w/ that..
post #15090 of 28843
Originally Posted by watsonte View Post
Okay, is there any need to calibrate after a certain break in period? Or can I go through DVE calibrate and enjoy?
As far as the AMP settings are concerned I noticed in store that when on High there were instances of TBE, medium and low resulted in less so I will probably go with low at first...Of course I might push it just to see what I can get away with before I notice anything.
calibrate anytime, but post yer settings please
I pushed AMP too. Ran on High for almost 2 weeks. Then tried Low and discovered something. There is a halo effect, we have called it vapors, that is related to AMP. On my TV (fw 2002) TBE is pretty much the same with any setting of AMP, and TBE only bugs me a little. Vapors is another story, and with AMP=Low, little if any vapors. Vapors bugs the hell out of me.
I get very little stutter. If I got a lot it would bug me enough to return the TV. I see it so rarely, I don't know if it is better with AMP on Low or not.
