Originally Posted by
sharpjunkie
Ok ran that test this is via VGA, im unable to plug the dvi in because I would have to remove my tv and reomove the wall mount to get access to my HTPC. This is at 120hz output from pc allegidly
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... SAMSUNG
Manufacturer................ Samsung
Plug and Play ID............ SAM032D
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2007, ISO week 25
EDID revision............... 1.3
Display type and signal..... Analog 0.700,0.000 (0.7V p-p)
Sync input support.......... Separate
Screen size................. 1020 x 570 mm (~48")
Power management............ Active off/sleep
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.640 - Ry 0.330
Green chromaticity.......... Gx 0.300 - Gy 0.600
Blue chromaticity........... Bx 0.150 - By 0.060
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 30-80kHz
Vertical scan range......... 56-75Hz
Video bandwidth............. 170MHz
Extension blocks............ n/a
Timing recommendation #1.... 1920x1080 at 60Hz
Modeline................ "1920x1080" 138.500 1920 1968 2000 2080
1080 1083 1088 1111 +hsync -vsync
Timing recommendation #2.... 1280x1024 at 60Hz
Modeline................ "1280x1024" 108.000 1280 1328 1440 1688
1024 1025 1028 1066 +hsync +vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
640 x 480 at 72Hz - VESA
640 x 480 at 75Hz - VESA
720 x 400 at 70Hz - IBM VGA
800 x 600 at 56Hz - VESA
800 x 600 at 60Hz - VESA
800 x 600 at 72Hz - VESA
800 x 600 at 75Hz - VESA
1024 x 768 at 60Hz - VESA
1024 x 768 at 70Hz - VESA
1024 x 768 at 75Hz - VESA
1280 x 1024 at 60Hz - Samsung
1280 x 1024 at 60Hz - VESA
1280 x 1024 at 75Hz - VESA
1600 x 1200 at 60Hz - VESA
1920 x 1080 at 60Hz - Samsung
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C 2D 2D 03 00 00 00 00
10: 19 11 01 03 68 66 39 78 2A EE 91 A3 54 4C 99 26
20: 0F 50 54 AF CF 00 A9 40 81 80 61 40 01 01 01 01
30: 01 01 01 01 01 01 1A 36 80 A0 70 38 1F 40 30 20
40: 35 00 FA 3D 32 00 00 1A 30 2A 00 98 51 00 2A 40
50: 30 70 13 00 FA 3D 32 00 00 1E 00 00 00 FC 00 53
60: 41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FD
70: 00 38 4B 1E 50 11 00 0A 20 20 20 20 20 20 00 4C
Display adapter
Adapter description......... RADEON 9550
Adapter device ID........... 0x41531002
Display settings............ 1920x1080, 32bpp
