Originally Posted by A.C
Exactly. The VAST majority of electronic devices use DC voltage. Batteries provide DC voltage. Most everything that gets plugged into a wall (AC voltage) gets converted to DC.
So in North America, 110 volt (AC) is converted to DC. In Japan 220 volt (AC) is converted to DC. The catch is that electronic devices do not use identical DC voltage (or amps). So 110/220 doesn't really matter. Only the DC voltage.
This camera charger uses 4.2V DC... however other devices use 9V DC. Some use 12V DC. So its just a matter of figuring out what the JVC requires and finding a brick that falls into that range.
Again all your questions and more can be answered by this link, which I've also posted previously. Read the comments.http://www.instructables.com/id/Run-...ugh-AC-power./
I have the second Radioshack adapter it mentioned and I am currently performing this procedure. Scalpel!
EDIT: Oh yeah. The JVC adapter needs 3V DC. 2AA batteries = 1.5V x 2 = 3v
EDIT 2: Success! The mod as described works! I will have pics up for everyone later tonight, and hopefully more good things to say.
I owned the Sen 595's.. & Own the Sen 212 pro & Sen 650's.. All 3 are great!! Can't compare the SQ of the Sen 555/595 to the pioneers cause I never heard the Pioneer 800C before..
Sorry if I'm speaking French to you. Maybe someone can explain it better then I.
