Well, I know the DAC won't be used on the go, but an LOD is all I need to just get the source signal anyway, so there shouldn't be a nees for the DAC on the go.
And yes, the CAL = D1001 with a cosmetic, rebadged difference. That's why you guys should take me seriously when I say that it rocks. It's not some random budget can. The D1001 still sells for $150 or so, and the CAL is $100 practically everywhere but on Newegg. I dunno why Newegg has it for so cheap, but Im not complaining. Try it out and tell me the DT770 Pro is better. I dare you. About the only thing the Pro does better is bass quantity and a larger soundstage (which is just freakish in nature to begin with for a closed can). The CAL has it's own big soundstage, and great overall balance.
Hell, check the 36 portable shootout by ljokerl on headfi. He rates the CAL incredibly high, losing in overall score mainly for it's mediocre isolation from external noise. I think it got a 8.5 in sound, 2nd only to the HD25-II which score a 9 for him. His thoughts pretty much mirrored my own except he thinks the bass is exagerrated at times. I don't see how, it's not even a basshead can...
I had the correct source selected on the AVR and would get sound on my HT but it was not passing it through the optical out for some reason... any suggestions? I thought this was how I was doing it before but maybe I am forgetting something?
