AVS › AVS Forum › Display Devices › CRT Projectors › Will My Sony VPH-D50HTU Do High Def
post #1 of 32
I have an early model of the D50 that does not have a card for 480p. It displays 480i but has a built in line doubler. The information I have on this projector is that it has 700 lines for TV and 1000 lines for HDVS (whatever that is). Does anyone know if this projector would display a High Def input from a Blu Ray or HD DVD player? It does not have an HDMI or DVI input only component, etc.
I have been considering replacing it with a current 1080p projector but I am reluctant to do so because it still has a great picture even though it has lost some of its brightness over its 8 years. If this projector would display the input HD signal from a BluRay of HD DVD player I would probably keep it for awhile yet.
I would appreciate hearing from someone who is familiar with this projector and its capabilities with current formats so I can make an informed decision regarding its future.
post #2 of 32
Hi PEH,
With a RGBVH BNC to VGA cable, connected to a HDFury you can plug in any HDMI or DVI source device you'd like. (For HDMI you would need a $5 or less DVI-HDMI adapter)
HDTV Set top box with HDMI/DVI output, Blu-Ray, or HD DVD can all be used.
Alternatively, a HTPC with a HD DVD or Blu-Ray can output to VGA although HD formats on HTPC can get complicated when connected to an analog display (due to HDMI).
I had a Sony 1271 (similar though a bit older then the D50) and it had a sweet spot around 660 lines.
I think 1280x720p or 1920x1080i have the potential to look very good on your display. 720p may be a bit soft (difficult to distinguish individual scan lines up close) but both would be a big step up from SD DVDs.
post #3 of 32
In of itself a D50 can resolve 1080i, but you have to be able to feed it that. I would use a Moome card HDMI or DVI or Wyman DVI is supposed to be good too.Also the Fury is a great choice. I just took my D50 down from the ceiling and put a G70 up feeding it BluRay and HD through a Switcher to a DVDO iScan HD+ scaler into a Moome HDMI card and it is mind blowing. D50 isn't the best at resolving 1080i but it probably isn't the worst either. Tons of info available here and at Curt's site as well. I had fun with my D50 for the last year the machine is what it is a 7" ES. I still watched a bunch of movies with a line doubler and loved every minute of it. Good luck and have fun.....ray
post #4 of 32
Originally Posted by voicecoils View Post
Hi PEH,
I have never heard of this. Does it really work? If so it is a damn site cheaper than buying a new projector. I may have to give it a try. Thanks for the info. You learn something new everyday around here!
post #5 of 32
Why not just feed the D50 component via 1080i out of the BR or HD DVD player? 1080p is far too high a resolution to feed those 7" tubes, 1080i will look much better, and no extra hardware required.
post #6 of 32
The D50 can certainly do better than 480i. But there seem to be a couple versions of the projector that have different inputs.
Does your D50 look like this on the back?
If so, its already setup to take component input on the input A (8). It will accept 480p, 720p and 1080i on that input as long as you go into the menu and tell it that its HDTV=YPBPR instead of RGB.
You could also get Moome's HDMI/Component IFB card or JohnHWMan's DVI IFB card. Both are HDCP compliant and would let you run a digital cable to the projector and use that in addition the built in Input A to have RGB and Component & HDMI or DVI on Input B.
There may be some sync issues and you'll have to experiment with how to best get it to start up and sync consistently. Generally, get the projector set correctly and on the input you want to use and then turn on the device providing the input. After that if you switch inputs it may not want to re-sync and you'll have to either disconnect the input or turn the device off and back on.
As was already said 1080p is way beyond this projector. My experience was that 720p was also pushing it a little too hard, and was softer than I liked. I found that 1080i looked awesome for HD material and video games. For standard DVDs I ran them on my HTPC at 540p and felt that was a good match.
post #7 of 32
Yes it does work apparently, click on the word "HDFury" in my above post and it will take you to curt's site where the product can be bought. The device not only converts HDMI/DVI to VGA but it also strips out HDCP.
I think you should spend minimal $$ and see what your PJ looks like at 720p/1080i. If it's not enough, or you have bags of money it might be time for an upgrade
post #8 of 32
My D50 does look like this except that it has 2 inputs ( A & B ) in a similar arrangement. However, I was given the impression several years ago when I tried to connect an original Xbox to it that it would not accept 480p. When I tried to play Halo I got a clear but double side by side picture. I was told at that time by the dealer that I would have to have installed a new card that would accept that signal. Maybe true maybe not.
Are you saying that I could connect a BluRay or HD DVD player using the component output on the source and the Y,Pr,Pb connections on the D50 and run it at 1080i by changing the setting to HDTV=YPBPR instead of RGB on that input? Do I understand you correctly?
post #9 of 32
Is there a setting on the source player that allows one to set it for 1080i output so that would work? What about copy protected material?
post #10 of 32
The component output is limited to 1080i. Feed that right into the set with component and call it a day.
post #11 of 32
No S...! Will that provide me with a High Def picture? What about movies that are HDCP enabled?
post #12 of 32
When changing input resolutions most projectors need re-converging this is most likely the double image you see. your dealer didn't know what he was talking about
If using component its not an issue
Athanasios
post #13 of 32
Curt, is there any difference between the A & B inputs on the D50. I am currently running a component input into A for standard DVD. Can I connect the component output of a BluRay or HD DVD player to the B side the same way and get 1080i?
post #14 of 32
Is soft = blurry?
post #15 of 32
Soft = Scan lines slightly overlapping.
PEH - Yes, you should be able to connect an xbox, blue-ray, or hd-dvd player via component drectly to the input you already have. With the device producing a 480p/720p or 1080i component signal and the projector set to HDTV=YPBPR.
Getting an HDFURY, moome card or other interface may be a good idea down the road but you should be able to run higher than 480i right now. Your dealer did you a big diservice telling you that you needed to buy an interface card to do 480p.
What you describe from your halo experience sounds like the xbox was sending a progressive signal, but the projector was expecting standard component or was still on RGB.
I encourage you to experiment with it. When you do get it to sync and run at the other resolutions, you will have to setup the convergence for that signal if it was never configured for that.
post #16 of 32
With regard to the Halo experience that is exactly what was happening at the time i.e., sending a 480p signal. I even knew that at the time but I did not know what to do about it. So I contacted the dealer and he told me I had to have installed a new card that would accept a 480p signal. Since I had another setup for gaming I passed on that.
As soon as I have the opportunity I will give this a try. I would much rather keep the D50 than replace it with the current crop of <$3000 DLP or LCD 1080p projectors since the D50 still puts out a great picture even after 8 years of use. Thanks for the advice.
post #17 of 32
Ever since learning that I can play BluRay or HD DVD movies through the component inputs of the D50 I have been madly researching the available players. One of the troubling things I discovered is that it would appear as though the only way I can get any of these players to upconvert standard DVD is through the HDMI output.
Does that mean that the only way I can upconvert standard DVD and get BD and/or HD DVD is by using something like the HD Fury?
post #18 of 32
My advice would be to take things one step at a time. 480p via component from a cheap progressive scan DVD player is going to be way better than the 480i you've been watching. So even if you have a HD-DVD/Blu-Ray player it will play the standard DVD at 480p which is better than you've had. HD material at 1080i via component will look really awesome.
Standard DVD being upscaled to 1080i or 720p is going to probably be better than 480p, but only marginally so. And yes, the restrictions on the way they are supposed to work keep them from upscaling standard DVD on component, so either RGB or HDMI are the normal options. There are some players that do not upscale on component out of the box but will if you enter secret codes on the remote - but I have no experience with them.
If you get 1080i dialed in and like the way it looks for HD material, getting a player that upscales via RGB, getting an HDMI input card or HD-Fury, or hacking a player to upscale via component are all options.
post #19 of 32
In pondering this whole issue further I have come to the same conclusion as you recommend, i.e., taking it slowly by starting with an inexpensive player and going from there. I will probably give that a try this weekend or next week and see what happens. I am, however, a little unclear as to the settings that will need to be used on both the player and the D50. Can you help with that?
post #20 of 32
Kris - Never mind. I went back and reread the earlier posts and you had already provided the setup information. Now all I have to do is implement you advice and direction. Thanks for all your help. I am really jazzed with the idea that my D50 can be made to look better since it already has a good picture!
post #21 of 32
After going back thru these posts I reviewed the one you posted regarding the configuration of the back panel and compared it to what is shown in my manual. There are some differences. First the model D50 I have is the D50HTU. In comparing the back panel there are these differences. On mine there is no #3 "INDEX" and there is also no#9. In addition my D50 has 2 sets of video inputs. Are these differences significant with regard to my D50's ability to display 480p, 720p and 1080i thru the component inputs?
post #22 of 32
OK, based upon earlier posts I had the impression, perhaps an incorrect one, that my D50 would accept and display 480p, 720p and 1080i. So today I went into the setup menu of my DVD player and set it up for progressive scan output. I then went into the D50 menu and changed the Input on Input A from component to HDTV=YPBPR. What I got when a signal was input from A was a garbled picture that would flash in and out. When I went to the menu screen of the DVD player the picture was very dark, not in focus and a double side by side picture. In order to get it back to the way it was I had to remove the signal before I could change the settings on the D50 back to component on A.
Am I missing something here or was my dealer correct when he told me that my D50HTU will not display 480p without a new card? Maybe I did something wrong, certainly possible, or there is some other setting that I need to change. It seems like some kind of sync issue but I have no idea what to do about it. Some help here would be appreciated.
post #23 of 32
Once you have both the DVD player and the projector configured for progressive scan, turn them both off. Turn the projector on first. Look at the menu and confirm that it is setup for HDTV=YPBPR. Then turn the dvd player on. As long as it goes directly into progressive scan, it should sync up.
If you do have to press a button or change a setting after the dvd player is on to get it to go into progressive scan, try disconnecting the cables - wait a moment, and then re-connect them with both the projector and the dvd player on.
post #24 of 32
Thanks for the help. I will try this tomorrow and report the results. Does it make any difference which input I use? The B input also has inputs for s-video and composite whereas the A input does not. I am currently using the A input.
post #25 of 32
You need to use an appropriate input.
Neither S-video nor composite will work with a progressive scan signal.
You need to use component video cables between the DVD player and the projector. Three cables, usually RCA style on DVD players. On the projector, you need to use the BNC style inputs on your Input A. The connectors are usually colored Red Green Blue and should be connected to the corresponding connector on your projector.
post #26 of 32
Yes, I realize that I was just describing the physical difference between the A and B inputs on my D50 in case it made a difference which one I used. I have always used the component (Y,Pr,Pb) connections on the A input. I just am not sure if it makes any difference, A or B input, when trying to get 480p to work.
post #27 of 32
If the one you're using never seems to work, try the other one.
post #28 of 32
Kris, after thinking about this issue all night, getting little sleep, I arose this morning ready to try your most recent suggestions in my quest to verify that my D50 will support something other that 480i. In that regard I set up both the DVD player and the D50 for progressive scan, turned them off and then back on in the order suggested. The initial result was the same as before i.e., an unstable picture that kept flashing on and off. I then disconnected the cables while both were on with the same result.
After a few moments of frustration it occurred to me that perhaps there was a setting in the menu that I had to change that no one had mentioned. In reviewing the menu settings I came across the setting SYNC SEL in the input setting. Having nothing to lose at that point I changed the setting from INT to EXT(HV) and low and behold it worked! The D50 is displaying a picture at 480p. I guess my dealer did do me a dis-service. I am glad I did not buy the add on card. One of the problems in all of this is that I think you and others may have assumed that I knew more about this than I do. Basically this projector was set up for me years ago and, for all practical purposes I have not touched it since.
As indicated by yourself and other people when I changed the input from 480i to HDTV I had to converge the lenses. As you might imagine this was pretty much a new experience for me. Since I had never done this before I am not sure if I have done it correctly. Perhaps you can be of help here also.
In looking at the manual it says to adjust the registration without an input. I left the projector set up on the A input but turned the DVD player off. I then went thru the registration process in the order outlined and got good covergence on all three colors. In the manual it says reset the data to factory preset level before doing the registration. When this projector was originally set up, having now gone thru this process, I can tell you that I do not believe that the fellow who set this up did so as a full registration saving the data as standard registration data at the end. For that reason I did not reset the data to factory presets before proceeding with the registration. After doing the registration for each color I simply hit the memory button. At the end I did not save the registration data as standard registration data because I was not sure what that does. Is what I did a problem?
Next I turned on the DVD player and fine tuned using the same process for input A only. Please let me know if I did this wrong and what I have to do to get it right. I really am a noob at this so I need all the help I can get. Thanks.
post #29 of 32
Glad to hear it finally started working out for you. Thats very exciting.
For each new resolution you use, you will have to setup the registration/convergence.
Hopefully the people who setup your projector did a good job with the fundamentals: physical placement, mechanical aim, lens flapping, electronic focus, and optical focus. Assuming that was all done well, what you need to do is setup the convergence.
The manual talks about setting it up without a signal, and usually that's whats recommended to set the thing up from scratch. You do the registration with no signal, save that to all inputs and then when you connect a signal it should be pretty close and you just need to touch it up.
In practice, it seems like many people (myself included for the first couple projectors I had) dont do that. Its frustrating to go throug the whole process with no input, get it nice and solid, then connect an input signal and see it go all out of whack. So I'd expect the people who setup your projector just did the convergence for the video signal you were using and the others are all pretty random.
You do have the remote control for the projector, right? It has buttons on the bottom row under a little plastic cover that you will need.
You'll have to go into the Service Mode with the secret code on the remote:
Enter Enter Up Down Enter
It will show you a prompt asking if you want to go into the Service Mode, say yes and then you can use the controls at the bottom of the remote.
Generally you setup the green first, then set red to match green, and finally set blue to match red.
You might want to go through each of the settings and make sure they are all set to 128 before you really start making adjustments. Its especially important to make sure the zone settings are all 128 since they will throw the other adjustments off if they have other values. Liberal use of the Memory button to save your current settings is a good idea once you've checked to make sure everything is set at neutral and then once you've started makign adjustments. I generally hit Memofy every time I switch from doing one adjustment to the next.
You will start with the Cent adjustment to center the green crosshair on your screen.
Then use the Size to get the edges of the test pattern to match yoru screen.
Hopefully green will be centered and the right size without having to use the Lin adjustment to change the linearity. If it does seem lopsided of off to one side, I'd recommend going back to the Cent adjustment and trying to get the center/size correct without using the Lin on green.
Then check the Skew to make sure the horizontal and vertical lines are plumb.
The Bow is used to get them to be straight up and down and side to side if there is any curve to them.
Then the Keystone is used to make the outer edges match the rectangle of the screen and be square in the corners. If I remember correctly, the D50 keystone has horizontal and vertical and when you adjust the green it affects the red/blue all at once.
After that the Pin is used to make the outer edges straight if there is any curve to them.
Hopefully, you can get the pattern nice and aligned with those adjustments. There are a number of Zone adjustments you can use to touch up individual areas of the image. The general recommendation is to try and get green setup as good as possible without using the zone stuff, and only use those adjustments on the red and blue if you really need to.
When I started trying to do convergence I would look at the whole screen and try to set the values and iterate until it looked good. But it often seemed like I would end up chasing my tail and going back and forth between various adjustments and never get it to be perfect. Then a more methodical method of using the digital values displayed and a little mental arithmetic to split the difference seemed to make sense and in practice has proven far more effective than trying to 'eyeball' the whole screen at once.
What I do now is focus on each adjustment on just one part of the screen at a time. Do each one just considering the horizontal or vertical components. First right and then left or top and bottom. Look at the number that gets one edge perfect, then do the opposite side and find that number. Split the difference and then do the other adjustment that compensates for it. After a few iterations I generally find that I end up at the right values that look right for both sides without pulling my hair out.
The adjustments work in pairs: Size and Linearity. Skew and Bow. Keystone and Pincushion. Each one in a pair will compensate for the other.
Starting with size and linearity, find the Size value that is perfect for the left side. Say its 110. Then do the right and find its perfect value, say 150. Split the difference and set it to 130. Then do the Linearity finding the value that is perfect for the left say 98 and then do the right say 122. Split the difference and set it to 110. Then go back and do the Size again - usually it will be much closer to correct for both sides and the difference between the ideal number on each side gets smaller and smaller. After a couple iterations its usually the same number. After doing the left/right do the top/bottom.
If the difference between two values is an odd number I usually bias it one way or the other, and often a single click iisn'tthat big a deal.
After doing the Size/Linearity, and Skew/Bow I usually go back and make sure the center is still good since sometimes those adjustments can knock it slightly off. Then after doing the Keystone/Pincushion on one rough pass go back and check the center, then Size/Lin, and then Skew/Bow before doing a couple more iterations on Keystone/Pin since they can throw the others off if they were way out.
Hopefully this description makes sense. The idea is to just look at each side of each adjustment in isolation, find the number that makes it perfect, then do the same on the other side. Split the difference between the two values and then do the same thing with the corresponding adjustment. Even if they start off way off, usually after a couple passes they converge (heh) on the same numbers.
post #30 of 32
Kris, thanks for the walkthrough on setting up the projector. I actually have a copy of the installation/service manual which does a reasonable job of describing the process. What was not clear to me in the process was whether it is necessary, before doing the registration, to reset the standard data to the factory preset. I did not do that before I went through the process you outlined. Is not doing that a problem? I am pretty sure that when they set the D50 up originally this registration process was not done so it was not saved at the end as the manual directs.
When I finished each color I simply hit memory. I did not "save the adjustment data as the standard data" by holding down the memory key for more than 5 seconds. As I said all I did was press the memory key but not for 5 seconds.
Is it necessary to reset the standard data to factory preset first? Should I go back and save the registration data as the manual states by holding down the memory key for 5 seconds or is it OK to leave it as is since I got good alignment during the process? I only use one input now set up as HDTV instead of component.
  Back to Forum: CRT Projectors
