post #1 of 1
Hello --
I also posted on the ReplayTV forum but got no responses. I'm hoping someone here might have some ideas.
I just had the DISH ViP222 installed and neither my Replay or my TiVo can change channels -- none of the IR codes are correct. Have any of you found a way to make this work?
I'm also wondering if its possible to make it work on the remote box -- the one without the receiver hooked to it directly.
Any ideas?
Thanks in advance --
