Budge Family Theatre
post #1 of 49
UPDATE:
Just wanted to do an equipment list at the start of the thread:
Projector: Panasonic AE2000U
Receiver: Yamaha RX-V663
Speakers: Klipsch Synergy Series
L&R Mains: F-1's
Center: C-1
Surrounds and Rears: S-1's
Subwoofer: Sub-10
Components:
PlayStation 3 (mainly for Blu-Ray)
Xbox 360 (gaming and now defunct HD-DVD)
Screen: Elite Screens EZframe CineWhite 92" fixed frame
Final room Dimensions: 11'W x 16'L x 6'10"H
Hey everybody, I've been a lurker for a while now. There are some amazing theatre's posted here, so I decided I'd give it a shot and build one. Any input or suggestions/critisim is appreciated! First off, here is a diagram of my plan:
http://home.comcast.net/~jpbudge/BudgeTheatre.JPG
I'm planning on an 11 x 16 room with two rows of seating. I haven't made any firm decisions on equipment yet, so I am open to recommendations ( I am on a budget though, so the less costly the better ). The only major problem that I have is that the ceiling is only 6'10" high, and if you look at my diagram there is an area at the end of the room that is even lower, only 6' high. I'm planning on putting the screen at that end so that there is room for at least a 10" riser on the viewing side. I would love to make it higher, but I don't want to squish the back row viewers too bad.
My equipment / snack room is located in a separate room behind the screen, I'm planning on installing a retractable screen in the lowered ceiling about a foot and a half from the back wall, that way it can overlap the door to the equipment room and give me a larger screen than otherwise possible. I'm planning on a 16:9 screen with a 96 - 104" diagonal. Surround sound will be 7:1, I didn't put the subwoofer in the diagram, but it will be located at the screening end in the corner.
The downstairs area used to be a small den and storage room, but I'm in the process of tearing down the wall to open up the area and begin construction. I'll post some pictures soon of the demolition. Wow this is turning into a long post, please let me know if you have any suggestions as I'm a newbie at this. Thanks!
-- Jeff "Bizarro J"
post #2 of 49
Your dimensions are very similar to my plans. Probably won't get to start this year though as other projects have precedence.
My plan is to have two rows with the front being a couch and the rear being comfortable bar stools or spectator chairs used for billiards rooms. That way I don't need a riser and I can reconfigure the seating at will (drag everything out and use for band practice, family party, emergency bedroom space, etc). Perhaps you could consider this as an option so your screen could go at the opposite end, and place a shorter throw projector in front of the low area. This would also bring your projector closer to the equipment (less $$ cabling), and the equipment area would be behind you.
Perhaps others could comment on side door placement (better towards the fron or better towards the rear) and swing direction. Swinging outward would eliminate cocerns regarding door clearance to seating.
Best of luck, keep us posted.
El Cid
post #3 of 49
I'd rethink the 10" riser. 6' would be too low for many people, my self included.
Try just raising the back seats and lowering the front seats.
Good luck
Chip
post #4 of 49
thanks for the comments, the spectator chairs might be a good idea and would eliminate the need for a riser. I would like to put the screen on the other wall, but with the lowered ceiling it may be too low for even the spectator chairs to be under, I'll have to look into that. Pics of the demolition are coming soon, just need to find my transfer cable for my camera.
post #5 of 49
Check out the harley davidson single reclining spectator chairs at a-1pooltables.com. They are very spendy but very cool.
Beachmfg.com also has the bahama theater chair.
- ElCid
post #6 of 49
Ok, finally found the cable i needed for my camera. Here are the demolition pictures. The small window at the opposite end will be walled up during final construction to make the room completely dark. Also the door will be replaced with a thick exterior door and possibly moved.
I also still need to rip the dry wall off the last two original walls and ceiling; that will be tomorrows project, along with taking out the last two studs remaining from the old dividing wall (they are not support beams).
post #7 of 49
Ok, I've begun some of the preliminary construction. I decided to go with your advice and put the screening wall on the other side, and I think I will go with spectator chairs for the rear seating. Here is a layout of the redesign:
http://home.comcast.net/~jpbudge/redesign.JPG
I'm going to go with a 96" diagonal 16:9 screen. I'm debating on whether to do in-wall speaker for the side and rear surrounds or to do wall mounted satelite speakers. Any opinions or suggestions on what to do there?
Here are some pics of my progress
(bar stools are just for reference, the spectator chairs will be a bit higher)
-- Bizarro J
post #8 of 49
Be sure you check projector throw distance and elevation relative to the rear seats (noise/heat/venting/etc.) before you commit to putting it at the rear in your new arrangement. You could adapt the stickied riser calculator for this purpose.
Maybe the projector could be located in front of the soffit?
post #9 of 49
Thanks for the input, I'm planning on putting the projector along the back wall. I've done the calculations and it should be fine, as long as someone doesn't sit dead center in the back row. As a fall-back however I am going to run some conduit to the front of the soffit, so if need be I can relocate it without too much hassle. I'll be putting in a ventelation duct above the projector at the back, and in front of the soffit just in case.
As for the projector, I'm leaning toward the Epson Home Cinema 1080 Projector
And I'm looking at a prepackaged satelite system for the speaker, definative technology. The ProCinema 800 is looking like a great system, keep in mind I'm on a pretty tight budget. I'll pick up another pair of matching ProMonitor speakers to use as the rear surrounds. I know there are much better speakers out there, but I'll have to upgrade to those farther down the road when I have some more cash flow.
-- Bizarro J
post #10 of 49
I've finished the demolition, just a few small things to cleanup from the old drywall. I added 2 new breakers, one dedicated to the lights and the other dedicated to the outlets. I have 6 can lights in the theater room, with the 4 closest to the screen on a dimmer and the 2 in the back on a seperate switch.
Here is a pic of my equipment closet, I installed a ventelation duct at the top that also connects to a duct above where the projector will go. I installed a in-line duct fan that is can be switched on and off by the light for the equipment room.
I made a soffit to hide the gas pipe in the equipment room, I still have a few small things to finish on the framing before the drywall starts to go up.
This is looking from the screening wall facing the back of the room. You can see I have already run my speaker wire, I'll be terminating them with banana jacks.
Here is were my side speaker jacks will be located, I plan on mounting the speakers just below the support beam running along the ceiling.
Here is the screeing wall, and my new insulated doors I still need to install. The yellow area is about the size my screen will be, 92-94".
That's it for this update. Good news is that I just got a pretty big promotion and will have the money to finish sooner, just not as much time. Kinda a catch-22.
-- Bizarro J
post #11 of 49
Have a listen to the Pro Cinema 800 and compare them to the Pro Cinema 1000. I put a pair of the pro Monitor 1000's in a master bath I just finished for my wife and they really are the little speaker that could. For their size, the 800's sound great but the 1000's sound even bigger. With a modest sub they'll do great for a smallish HT. I look forward to your progress as I'm starting my own similar sized room myself. I just wish I had a larger basement and a higher ceiling.
post #12 of 49
Thanks for the tip, I'll have to make the comparison. I've also been looking at these SVS speakers, I've read some good things about them so I'm keeping them under consideration.
Ya, my ceilings are also pretty low, 6' 10" at the highest, so I feel your pain. My house was built in 1963, so I guess they just never thought of it being used for anything but storage back then.
-- Bizarro J
post #13 of 49
Wow, I can't believe it has been so long since I've been able to work on my theater. Well I have made some progress. I'm almost done with the insulation, all I need to do is finish covering the small window with some MDF painted black. Then I can finish the insulation in the ceiling and start with the drywall. I'm still trying to decide if I want to do it myself or pay someone else. Judging from how long it took me to do the insulation I better hire it out. Here are some picks:
The boxes on either side contain the speaker cables for the left, right, center, and subwoofer. The box at the very top middle contains 2 ethernet cables, one for an infrared repeater and the other just in case I need something else put in, such as a motion sensor bar for a Wii.
I will be putting up a 12" deep shelf just below the USB/Ethernet cable box that will go the length of the entire back wall. The door is just placed there, I'm waiting for the drywall before I set it. My side speakers will be going up on each side just below the main support beam.
This is looking into the equipment room/office from the doorway in the theater.
Originally I was planning on the Epson Home Cinema 1080 UB, but I've been looking into it and I think that the Panasonic AE2000 is the way I should go. I've decided on an 7.1 SVS speaker system. If anyone has any opinions on these choices let me know, I'm open for suggestions. I'll probably have to buy all the equipment over a few months time, I hate using a credit card. The projector will come first, and I can use my old Pioneer speakers and reciever until I can upgrade.
post #14 of 49
I can relate to being away from the build for a while. I started mine 6 months ago, haven't touched it in 2 months and it will be another month before I can get back to it. I'm at about the same point. Wiring is about complete, insulation in and getting ready to sheet rock. Yours is looking good.
You asked for opinions on your speaker selection. Speakers are so personal that it mostly comes down to what sounds good to you. I'm not sure if you are in a location where you can hear the SVS's or not. I can't find them anywhere around me to listen to them. I've always been partial to Definitive. Again a personal thing. I just think that their high and midranges are great and as most anyone can thump away on a sub, the high and mid ranges are what makes it for me. I don't believe they package a 7.1 but you can always add two more satellites to make the 7.1. If you have time and are interested in comparing, they have a series called Pro Cinema that comes in a 600, 800 and 1000 models. These look comparable to the SVS's. May be something to compare the SVS's to. I've attached a review of the 1000 series for your reading pleasure. I believe these run between $799 and $1299 depending on the model. Not sure if this is in your SVS price range or not.
Good luck on the rest of you build and keep posting pics as you get things done. It keeps me motivated to keep going on mine.
REVIEW_2331.pdf 258.6826171875k . file
post #15 of 49
Good luck as you get started again! I too can relate as I had to take a 5 month break from my build last summer right about where you are now - after insulation but before the sheetrock went up. I did the drywalling myself, but if you have the cash and not the time, I'd hire it out because that part went on and on and on....
Good news is - once the mud is up and sanded, the rest goes fast and is a lot more fun. I've just about "finished" my build now, which is similar in size and scale to yours (15' x 8' x 6'8" finished ceiling height, 96" diagonal screen). Good call on nixing the riser - I can tell you personally that it would be rather uncomfortable.
post #16 of 49
nice progress. DIY'ers do such a nice and neat job with putting in the insulation. contractors are more of the stuff and run nature.
as for speakers, i like Axioms, but that is what i have .
later.
post #17 of 49
Thanks for the comments, I have looked into the Pro Cinema series from Definative Audio, they seem to be priced pretty close to the SVS setup I'm looking at. I think that Best Buy has them, maybe I'll go see if I can give them a listening to.
It's good to know that I'm not the only one that has been delayed for an extended period of time. I'm hoping to have the sheet rock up and finished by the end of the month. *knock on wood*
post #18 of 49
Made some progress this weekend. I started insulating the ceiling and covered up that pesky little window.
I started by painting some MDF black, 3 or 4 coats did the trick.
Then I cleaned the inside of the window really good, I won't be able to clean it again for, well ever, I guess.
Next step, fitted the MDF into the window, black side out. I caulked (sp?) around the edges with clear flexible caulk.
Then put in the insulation. No more window!
From the outside it just looks like a dark room. I still need to clean the outer window, I need to buy some more powerful cleaner for the mineral buildup.
I think I'll hire someone to do the dry wall before the end of the month. Then the real fun can begin!
post #19 of 49
Well the drywall is not yet up. But it will be up by the end of April, I've found someone who will do the job for materials plus labor, no bid involved. He is a friend of a contractor friend of mine, so I know he will give me a good deal and do a good job.
I've been doing some shopping for the room, my wife and I found a great deal on a leather sofa we both liked. Here is a picture from the web, I'll take some more once it arrives. We have seen it in person and it is very comfortable. It is a sectional, but we think it will help with providing more seating. Here is a stock photo I found online:
We are still looking around for some spectator chairs for the back row.
post #20 of 49
Make sure you post some pics when your sheet rock gets done. Looks like it is coming along nicely. Always good when the "wife" is involved AND motivated as well.
post #21 of 49
I did a very similar treatment to a couple of full sized windows in my build. But I thought about the access issue. What I did was remove the window lock and screwed the window tightly shut with stainless steel screws from the outside. That way if I ever need to get behind the glass I can. I also can remove the windows for repairs without too much effort.
Just something to think about before you hang the drywall.
post #22 of 49
Hey bizarroj:
I can't help but ask if the name of your theater is from your last name...if so, I am also a Budge with a lot of family and origin in Utah. Anyway, your theater space looks ideal for what I would like in my own home. Keep up the good work man!
post #23 of 49
Originally Posted by ABSiNTH View Post
Hey bizarroj:
Yes, my lastname is Budge, so chances are pretty good that there is some relation there. I live in the Ogden area, but I know that a lot of Budge's are in the Logan area and most are decendants of William Budge from Scotland who came here in the 1800's.
It has definately been a challenge working with the low ceiling, but I think it will be quite cozy when I'm finished.
BigmouthinDC - I thought about that as well, but since the window is so small and is located at the back of my house I think I will buy some landscaping bricks and cover it up completely in the back. Then maybe plant a shrub or something in front of the window sill.
post #24 of 49
Superior!
post #25 of 49
Well I thought it would never happen, but drywall is almost done! They came out today and hung it and tomorrow they will come out and do the finishing work. It's starting to actually look like a usable space now! I got a great deal on the drywall from my contractor friend. They are doing the whole space, 11' x 22' divided into two rooms, for $1100 bucks!
I'm not going with double drywall, the only room nearby is the living room directly above, so I'm not concerned with complete isolation. I just want it to be fairly muffled.
Here are some pics:
screen wall
looking towards the back
equipment closet
window in equipment/office room
post #26 of 49
Drywall is almost complete, they did the mudding and will be back on Monday to sand and do the texturing on the ceiling. I'm thinking of having them texture the two side walls as well, thoughts?
Previously I was dead set on an SVS 7.1 speaker setup, but now I'm thinking of going a different route to save some cash. I was thinking up going with Hsu Ventriloquist V-12 setup, using the center and 4 surrounds and pairing them with SVS SCS-1's for the front L and R, plus an SVS PB10-NSD for the sub. I'm not an audio expert, does anyone see any problems with this setup?
post #27 of 49
Wow, after 4 or 5 months of no progress things are moving pretty quick now. Forget my last post about the speakers, I just made a fairly compulsive purchase at Best Buy today. They had a deal going on a set of JBL speakers, that I wasn't too interested in, but they were sold out so I asked if I could get some special pricing on the Klipsch Synergy speakers that I had been eyeing for a few weeks now. I demoed them and really liked the sound. They gave me a great deal, won't post specifics here but I got F-1 floor standing speakers, C-1 Center, and 2 sets of S-1 Surrounds, the 10" sub, and the new Yamaha RX-V663 receiver for an awesome price, basically got the receiver for free.
Here are some picks of my new toys waiting for me to finish the room.
Now all I need is a little thing called a projector, some think that it's a fairly important piece to the home theater equation. I'm 85% sure that I'm going with the Panasonic AE2000, but the Epson HomeCinema 1080 UB keeps creeping into my thoughts. The only thing that worries me about the UB is I hear it has a lot of quality control issues. I know that the Panny has dust blob issues, but I think I can avoid that with a simple DIY filter attachment. Any suggestions?
post #28 of 49
I personally would go with the Panasonic AE2000. I have the older Panasonic PT-AE900U and love it.
post #29 of 49
It looks like you'll be enjoying your theater very soon.
post #30 of 49
Please post back how you like the Yamaha RX-V663. I'm looking at that or the 863. I'll probably go 663. $450 is a whole lot for an extra HDMI input and upconversion that I don't need.
