AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Sticky in Home Theater Computers: TesTed HDCP Components
post #1 of 2
Suggestions on HTPC are good in forums, but what I run into is the BIG
problem of HDCP Components (Really being 100% - not just partial Complantent).
Mainly Video Cards and LCD Monitors, some say HDCP - but after searching
web, some are not - some partially.
Others only work if you use AnyDVD, etc.
A sticky or something for TRUE HDCP Compatability?
post #2 of 2
Sounds like an idea, but we stick posts that the member make usually on a subject after it is looked at and considered something of overall interest. This may be, but we really are not a computer monitor site.
  Back to Forum: Forum Operations Center
