Hi Rob,
Like all the others, GREAT BUILD!!! You have saved me from much headache and I have not even begun.
My dimensions are 10.5x17 with 9' ceiling height and in a basement with three concrete walls and and a 2x4 drywall wall. One of the concrete walls has a window that I will be covering. I will attach some pictures.
What did you use for bass traps? I have purchased the Klipsch THX Ultra2 and will have a very serious bass situation. Also, as if you cannot guess, I am going to plagiarize the hell out of your design so consequently I will need to modify the speaker housing in order to accommodate a larger square speaker. Anyone care to chime in here with suggestions?
Would it be a bad idea acoustically to place all the speakers (front) starting left, sub, center, sub, right (read: on the same horizontal plane directly below the screen)? Or aesthetically?
Ben
Ben
