Hello all,
Here is some background information. I listen to music 95% of the time and do some light gaming 5% of the time. I am usually within 3 feet of my speakers, have a small room and I don't plan to play loud. As a first time buyer, I really want to buy new. I have three receivers picked out and my budget is $250(I can go up if possible, but I really want to stay in this range). Feel free to recommend others within my budget. Sound quality is my main concern.
Source
I don't have a tv or dvd player. The only source is going to be from my computer, mainly FLAC files. My soundcard is a Chaintech 710, which has optical out.
Speakers
I decided to go with the HSU HB-1 Horn and STF-2. I will NOT be adding more speakers. I prefer 2.1 and I plan to buy these and keep them for a long time.
Receivers
Harman Kardon HK3480 Stereo Receiver
Onkyo TX-8522 Stereo Receiver
Panasonic SA-SR55S
Here are my thoughts:
The Panasonic is cheap and has digital input and has some crossover frequency control.
The HK and Onkyo are made for stereo but do not have digital inputs or crossover control.
1) Is the digital input is going to be that much better?
2) Would it matter quality wise which crossover I use? (The crossover on my sub or the one on the Panasonic)
Which one do you think would be better as I've heard good things about these receivers? Hope I provided enough information. Thanks in advance.
Source
Speakers
Receivers
Panasonic SA-SR55S
