hi jim, yes, thats what i plan to do, since it was about 10 seconds to add/remove either, ive read your posts for years with my xfi, i guess you know for sure that the center/surrounds cant be hardware modified?
also, after 4 emails i finally got a real response from auzentech, they said that they put in the request today to creative (i guess creative provides the proper 'paths' in software for auzentech) so that in the next revision bass redirect will be in entertainment mode.
blingo, the one they mail you, i 'believe' that youll see theres one opamp on top, and one of the bottom, of the 8 pin adapter they sent you. i just used my fingers to pull off the old and then popped the new right in. if youre working on anything with pins, make sure to try to go on as little angle as possible so you dont bend the pins out of alignment. make sure you put the old one in correctly, the small indentation should be facing the cards edge, representing pin1.
