I just hung my cabinets over the bar (milestone - this is the last "construction" project! Yea!). These are custom sized cabinets with floating wood panels. I want to cut the panels out and have them replaced with reed glass. So two issues - best way to cut the panels out? I don't have a table saw so I was thinking - just drill 1" holes in each corner of the panel, then use my jigsaw ? Is there a easier/better way to get the panels out?
Then there is the fun part. I was thinking that it would be cool to have lighting inside the cabinets so they would glow. Any thoughts on what type of lighting to use? I am somewhat concerned about heat buildup inside the cabinets if I put lighting in there. So LED lighting? It needs to be either - dimable - or low enough lumens (preferred). Electrical is no problem - there are outlets below the cabinets on both sides, and I can put a short run of romex up to come out inside the cabinets.
I have never used a router before so I will build a jig and practice on the scrap wood first. I think I got the correct bit it is a "straight trim bit". There might be a snag in this plan - it looks like there is a small metal plate or big staple that has been shot into each corner to reinforce it. Any idea how to get that out of there? My plan at this point is to route out all the way around except for the corners, then use a chisel to take the wood top off the staple/plate - then pull it out with pliers?
