AVS › AVS Forum › HDTV › HDTV Technical › Connecting Cable Line and Antenna
post #1 of 6
I have a TV that has a single ant in port. I would like to be able to connect both my cable line (which I do not subscribe to any HD programming) and an indoor antenna to receive OTA HD stations. I was thinking about using a cable splitter, but I am under the impression that cable splitters are meant to connect one antenna source to two TVs, not two antenna sources to one TV. Any help is welcome.
post #2 of 6
There are some situations where a splitter can be used as a mixer. However, you can't do what you want since your cable company uses some of the same channel frequencies as your OTA broadcasters for different programming.
post #3 of 6
Ok thanks.
post #4 of 6
You'll need an A/B switch and possibly need to rescan for channels every time you switch depending on the set or you can use something like a VCR as your analog cable tuner and just switch inputs on your set.
post #5 of 6
Thanks. I'll look into that.
post #6 of 6
One more thing, if your TV has a QAM tuner, hook the cable up and do a scan, if your local cable company is broadcasting digital locals in unencrypted QAM, you will pick them up and possibly not need the antenna.
  Back to Forum: HDTV Technical
