AVS › AVS Forum › Video Components › Home Theater Computers › What is a really good Audio Card that doesn’t take up a 5.25 Drive Bay?
post #1 of 4
What is a really good Audio Card that doesn't take up a 5.25 Drive Bay?
I want to buy a really good audio card but I don't have any 5.25 Drive Bays to spare. What I need is something that will give me bit perfect DD, DTS, and PCM passthrough through optical or co-axial. It needs to have 7.1 channel analog audio output and those need to be as high quality as possible(at least 116 DB SNR). A nice to have would be something that can encode to either DD or DTS. What would be a good choice?
I saw this card on newegg.
ASUS Xonar D2 7.1 Channels PCI Interface Ultra Fidelity Sound Card with Complete Dolby/DTS Sound Technologies - Retail
It seems to have everything listed above(118 DB SNR, DTS connect, DD live, and optical output) for $189.99. Is there anything cheaper that meets these specs?
http://www.newegg.com/product/produc...82E16829132001
I didn't see where you connect the optical output on this card. Can anyone confirm where the optical output is?
post #2 of 4
How bout any of these other cards? Are these any good?
AuzenTech AZT-XM71 7.1 Channels 24-bit 192KHz PCI Interface Auzen X-Meridian 7.1 Sound Card – Retail $169.99
http://www.newegg.com/Product/Produc...82E16829156002
HT OMEGA CLARO Plus+ 7.1 Channels 24-bit 192KHz PCI Interface Sound Card – Retail
http://www.newegg.com/product/produc...82E16829271003
E-MU 70EM896206000 7.1 Channels 24-bit 192KHz PCI Interface 1212M PCI Digital Audio System - Retail
http://www.newegg.com/product/produc...82E16829110015
post #3 of 4
I would buy an AuzenTech X-FI Prelude (msrp $199) at first choice. If that's too much, I would buy either the AuzenTech X-Meridian ('better than 15db) or the Bluegears B-enspirer (around $100) (which is the card I use in my HTPC). Both use the C-Media CMI-8788 chipset.
post #4 of 4
there are a lot of sound cards that dont require 5.25" drive bays. they'd simiply have a optical/coax port on the card itself where you'd connect your optical/coax cable to the back of the case.
i'm using the auzentech x-plosion 7.1 myself that i paid $70 for from newegg. depending on your budget, you might want to wait for auzentech's upcoming Prelude card which features creative's x-fi chipset. for mp3 playback the 24bit crystalizer from creative's x-fi is a nice feature to have.
