AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How can I tell if I've blown a fuse?
post #1 of 3
My NHT A1 amp made a large pop all of the sudden and the light turn RED instead of green. I have checked the manual and the causes can be the wires or a blown fuse. I just check the wires and everything seems fine.
They have been the same for three years and nothing has been move around back there. I took the fuse out and all I can see is a tiny wire inside going the lenght of the fuse. I don't know if is suppose to be two, or if it turns black when is blown. Can someone give me some feedback?
post #2 of 3
If you look at the fuse, the wire inside may be broken/discolored. If you are unsure, just find the exact type of fuse and replace it. I am far from an electrical guru, but that's what I would do if I'm unsure if it's blown.
post #3 of 3
You most likely would not have the fault indicator if the fuse was blown. I would start by disconnecting the input and speaker wires to see if it corrects the fault. Often times something external to the amp causes the protection to trip. A bad input or shorted speaker wire are the most common reasons and amp will go into protection. If you heard a "pop" one of the large filter capacitors may have vented, meaning the top opened and puked the cap's internals onto the circuit board. I believe the warranty is three years on the X2 and A1 electronics, if it's out of warranty any competent shop should be able to repair it.
Good Luck
Ron
