I suspect this topic has been covered, but this forum is so vast it could take days to find what I am looking for.
Two weeks ago I purchased a Mitsubishi WD-65732 (it was for the DVI mainly which they conveniently removed for later models....DRM anyone?)
Earlier this week I broke out my old NES, SNES, Sega Saturn and Sega Dreamcast among others to find that the ones I just mentioned have a compatibility issue (but for some reason my N64 works fine
) The image appears on the screen, but jitters up and down violently and if I try to look at it it gives me a good headache within 10 seconds. I called Mitsubishi and they say it is an incompatibility with a feature on the TV trying to up-convert every signal it receives to 1080p and with very low resolution inputs it can't compensate well enough to produce a stable image. This is a borderline deal-breaker for me as the TV was meant for gaming. On my NES I have used the old RF Adapter -> ANT as well as composite, SNES I have tried composite and S-Video and the Sega Saturn and Dreamcast only the composite as that is all I have. The Dreamcast has been hit or miss though - some games work fine and the boot up menu system works fine, but some games exhibit the same symptoms as I have described.
My question is if there is a box or any other solution that any one is aware of that will fix this issue. The images appear on the television just fine, only unstable and I can not believe that it would take much to alleviate the problem.
Thank you for any help.
) The image appears on the screen, but jitters up and down violently and if I try to look at it it gives me a good headache within 10 seconds. I called Mitsubishi and they say it is an incompatibility with a feature on the TV trying to up-convert every signal it receives to 1080p and with very low resolution inputs it can't compensate well enough to produce a stable image. This is a borderline deal-breaker for me as the TV was meant for gaming. On my NES I have used the old RF Adapter -> ANT as well as composite, SNES I have tried composite and S-Video and the Sega Saturn and Dreamcast only the composite as that is all I have. The Dreamcast has been hit or miss though - some games work fine and the boot up menu system works fine, but some games exhibit the same symptoms as I have described.My question is if there is a box or any other solution that any one is aware of that will fix this issue. The images appear on the television just fine, only unstable and I can not believe that it would take much to alleviate the problem.
- It makes me quite sad since I am quite the 'retro gamer' - I was looking forward to playing some of my old games on my new and quite expensive TV
