Originally Posted by Stew4msu
Agreed, but you'll notice in my example the problems were all ones that needed set replacement (i.e. equal in level of problem). I don't care about problems with batteries. The number of critical problems in the A3000 thread is very minimal. Take that for whatever it's worth.
Yes, your EXAMPLE used replacement problems. BUT, your ORIGINAL statement talked about problems discussed in the A3000 thread (no mention of replacement). So, I figured your EXAMPLE was an EXAMPLE, just as mine was.
