Originally Posted by soyuppy
It was replaced by the service guy. I had purchased the extended warranty service, so I was entitled to one free bulb replacement. If this number has to be reset manually after the bulb is replaced, then for sure that didn't happen. And this number would represent since the set was put in use, which is Sep 2007, along with 1 bulb replacement? How does one reset this number?
I'm trying to recall but usually the set asks on the screen after a lamp replacement something like, "Did you replace the lamp?" and if you answer "Yes", then it does the reset. Do you recall that ever happening after your lamp replacement?
