Originally Posted by Pacbellguy
Ok.. maybe I'm having a similar problem but I originally thought it was my Denon 4308. After I updated my firmware to 9.03, I started losing HDMI sync. I have my PS3 connected via HDMI and my U-Verse box connected via component to Denon 4308. I then have Denon connected to Mits 73833 via HDMI. After system is on for about 15 minutes or so, I'd lose picture. Sometimes it would just go to a blue screen and sometimes it would also be a garbled green screen. It happens with both PS3 and U-Verse, so I know it's not them. I also turned off the CEC command in the Denon and that doesn't help. I've tried swapping out HDMI cables and well as use different HDMI ports in the back to no avail. The timing of my problem seems to be after I updated to 9.03 as well as changed my bulb. I'll have to see if I get a flashing error light after it happens.
OK.. here's an update. I had actually replaced my bulb housing with one that I did not get from Mitsubishi around same time I started to lose my HDMI as well as component input pictures. I kept my original bulb since it had not burned out completely and put that housing into the television. After quite a bit of viewing, I haven't had the problem reoccur. What could have possibly caused the problem if it in fact was the changing of the bulb housing? Bad connection, excessive heat? Anyone else have any trouble after replacing bulb housing with non-OEM bulb?
A UPS might help if you have no other option for the printer
