AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › Industry Insiders Master Q&A thread IV: ONLY Questions to Insiders
Industry Insiders Master Q&A thread IV: ONLY Questions to Insiders - Page 91
post #2701 of 4687
Originally Posted by benwaggoner View Post
Normally we start with a 10-bit 4:2:2 master, and then run through our own special dithering software to convert to the 8-bit 4:2:0.
Scans and archives are normally at more than that yet, but most titles start the HDM workflow with the 10-bit 4:2:2 at native resolution.
Oops, hard to keep track - I just added up the numbers to remember 4:2:2 as 8-bit... duh. The above should obviously read 4:2:0 VC1 encode.
Now, how brutal is the dithering process from 4:4:4 down to 4:2:2? Do you guys make tools for the post-production part of the chain, assisting with the real-time capturing components? This is not at all that MS vs Sony crap, but I've always found it very compelling how Sony manages to be everywhere along the chain, from the Studio that makes the film, through the post houses, mix-down studios, digital cinema, home theatre, etc. We all know about the consumer level stuff, natch, but I continue to be interested in the back-end stuff, the crazy pro-level things that even some post houses can't touch and farm out to the big boys. In other words, does MS have a foothold at all at a pro level with film production that we may not know about?
post #2702 of 4687
To Microsoft insiders: are there some HW limitations in the Xbox 360 that prevent the HD DVD playback to get 100/100 on the HQV test? Or can it be fixed with a software update?
I'm referring to this article:
http://gizmodo.com/gadgets/xbox-360/...her-330916.php
Thank you.
post #2703 of 4687
Originally Posted by Joe Bloggs View Post
In the link about scanning films (such as Blade Runner)
http://www.soundandvisionmag.com/fea...d-is-made.html
they say "sometimes you have to add grain". Isn't this a bad idea? If the film itself didn't have visible grain why would they want to add it? Forget what is said in the article. That can't be the correct way to do it can it?
Well, if you have a notable variance in the amount of grain between shots, or in the amount of grain inside a shot (like mixing CGI with film elements) it can be distracting. So you might need to add it in to make in more seamless.
Also, the release print process adds additional grain, so if the filmmakers assumed a particular amount of grain would be added there in order to get to their intended look, it might need to be enhanced in the compression source in order to get the same look as it had in the theaters.
post #2704 of 4687
Originally Posted by sharkshark View Post
forgive the -minor- lapse in etiquette, but as per my questions above, wouldn't you know that this launched today...
It's a fun article that addresses things that many people ask about here of our (patient) insiders, and thought for those nerdy enough for AVS, this might be of use...
any insiders wish to add anything of note to the article?
Good stuff. I like that it clearly showed that film restoration is as much an art as a science. It's not all about algorithmic number crunching, but about smart people making creative decisions about how to make the content "more like itself."
That's always what I've imaged I'd do if compression ever gets too easy .
post #2705 of 4687
Not that brutal at all. We've designed ours so that it provides the minimal disruption in order to prevent banding.
At Microsoft, we don't make a whole end-to-end solution like that, although of course we make many of the components used in all kinds of professional video products (WMV import/export, and of course lots of video gear is running Windows Embedded, even if you never see the BIOS screen).
post #2706 of 4687
...I was imprecise before, but you may have thought I was making the same mistake twice - if I understand what was posted above, you guys get 4:2:2 masters that have to be converted (using your tools) for VC1 encoding (I assume that dither pass is done before any encoding rather than simultaneous with the compression).
However, I was wondering about slightly higher rung, namely, the conversion from, say, teh 4k, 4:4:4 monster file (terabyte+) dithered down to 4:2:2 to then be =re-dithered= to 4:2:0... Is that the way the workflow goes? If so, do you play a role in that phase, or is that done with really, really hardcore crazypants devices?
I'm fishing for hints about what the budget-no-object kids get to play with, what can I say...
post #2707 of 4687
Thank you.
Its "just" software. See my earlier reply as to why interlace support is not a big priority for us.
post #2708 of 4687
There's no such thing as budget-no-object, alas .
Our software is certainly capable of coming straight from a high-bit 4K as source for conversion to 8-bit 4:2:0 1080p, but it'd be pretty slow. I don't know if there have been any full features using that technique directly, but it's certainly feasible.
Bear in mind the DI isn't tweaked for HD color space (709), so there may be some creative tweaking required. So most HD discs are made from that 1080p master, be it tape or file, that's properly 709.
post #2709 of 4687
Ben
When you encode a movie to HD DVD and then port it over to BD is there any limitation for the HD DVD encode that you cant use because the port?
post #2710 of 4687
The main one is that BD allows a smaller number of B-Frames than HD DVD. Not a meaningful practical difference for quality very often, but it does limit the ability to squeeze bits of out the credits in a few cases.
There's only one movie I can think of off hand where that resulted in different encodes for a BD/HD DVD title.
post #2711 of 4687
why would BD have a different requirement when it comes to B frames; isn't that specified in the VC-1 and H.264/AVC specifications ?
post #2712 of 4687
And how does B-frames work?
My guess is that they give you the ability to add seperate element/frames and still keep the main scene intact without that element further impact on the frames that comes after?
Because I saw PC playback of Riddick once and it couldnt handle strobing lights, so that should have been a B-frame issue in the software?
post #2713 of 4687
My question is to Roger Dressler & Dolby Labs. Some enthusiasts believe Dialogue Normalization has some significant negative impact on the audible fidelity of a signal; in fact, the noise some has made has gotten Sony to disable it on some of their releases.
Personally, from my own experience with sound processing and normalization processes, I don't see singificant audible degradation as feasible since it is all done in the digital domain and it is fairly easy processing to do. I also like the idea of not having to mess with the volume knob between features. But, I'd like to hear Dolby's take on it.
post #2714 of 4687
Not quite. Both AVC and VC-1 have richer specs than either format allow. For reasons specific for the applications (e.g. trick play) a number of restrctions are put on each codec.
For reasons that blow my mind, no one from BDA group consulted us in creating the profile for VC-1 which they used. I do understand however that they are attempting to fix the B-frame profile issue. But have lost track of where they are on it....
post #2715 of 4687
While we still are at VC1 theme
How does the median filter work that helps with the grainencoding?
post #2716 of 4687
Could this grain be modelled in by the player in realtime? I think someone said AVC has this option but it isn't currently used. Could VC1 have a similar option, so that for people who don't want lots of artificial grain or image degradation and would like the picture quality obtained from the best negative/IP available even if some shots don't quite match up to composite shots, those users could select the option to disable this realtime fake-grain addition (because, if you have some poor quality/grainy shots in the film, some people may not want all the rest of the film to be reduced in quality to match the poorer quality of these minority of shots).
Also, for films that have CGI composited into them (ie. I don't think Blade Runner would have had much other than displays?) - couldn't just the CGI portions have the added grain to match whatever grain was in the live action elements - instead of adding grain to the full frame?
Also, for recent films, which would have been colour graded/composited etc. digitally, do they generally scan the whole film nowadays? If so, after they've done this post production work on this digital intermediate is this version always the version used for the HD-DVD/Blu-ray or do the output it to film etc. before re-scanning it for HD-DVD etc. releases (I'm assuming the latter wouldn't be done).
post #2717 of 4687
Dave,
Have you heard anything about Warner switching stances soon? Lots of buzz going around.
post #2718 of 4687
To any insider: is there any news on HD DVD burners for PC?
post #2719 of 4687
Robert,
I fully expect that Warner will make an announcement at CES this year. As to which way they will go, no one knows with the exception to the guy who will make the call with WHV. I'm sure he is looking at this whole situation from every angle and holds all the cards in the format war. IMO, the side Warner chooses will end up "winning".
post #2720 of 4687
Originally Posted by Dave Vaughn View Post
Robert,
Dave,
so do you think Warner choosing a side in CES is pretty much a done deal?
post #2721 of 4687
If I was a betting man, I would say yes. As to which way they will go, who knows?
post #2722 of 4687
I would think Warner knows. Both BD and HD DVD both look desparate to me and I think it has to do with an impending decision by WB. BD players are being given away with the purchase of a HDTV with a zillion movies and HD DVD players are being sold for the cost of 5 movies and you actually get 10 movies with the purchase. If you have an HD DVD player and want to buy several titles it is now cheaper to buy a new player and get all the titles that come with it than it is to just go out and buy the movies alone.
David - why would WB now be willing to "leave some money on the table"? Do you think that WB is now afraid that two formats will "kill" both? Personally, if I were WB I would go HD DVD exclusive in order to get the BDA exclusive studios to sit down and negotiate full neutrality for all studios and then offer them all a deal for TotalHD.
Cheers,
Grant
post #2723 of 4687
A question to Dave,
Over the past few years, the movie business has become global. Hollywood studios depend on foreign markets -- both video and theatrical -- to cover the costs of their movies (especially the big budgets), and make money.
Recent data has shown us that Blu-ray disc sale ratios are consistently better in some key foreign markets. For instance, BD outsells HD 3-to-1 in Europe and 9-to-1 in Japan. These territories represent the vast majority of worldwide film sales.
So, do movie studios like Warner think globally?
Is it possible that Warner might choose Blu solely on the basis of its better worldwide penetration, even if in the US BD doesn't outdistance HD from its current 2-to-1 ratio?
Clarification: I'm speaking of film business and therefore disc sales -- not hardware units.
post #2724 of 4687
David:
So you disagree with my post?:
Think what would happen if "studio shuffle" was played out at CES . .
It will then make all other news pale in comparision. Because that is all the media will latch onto.
Lots of PO'd companies who have spent millions getting new products ready for 2008 and may not even get any press other than an OBTW.
post #2725 of 4687
Originally Posted by Azumi View Post
A question to Dave,
The thing with these ratio's that people aren't taking into consideration is that yes, by percentage, BD has a lead in disc sales, but when you look at the overall numbers, they are less than 1% of DVD sales. So in reality, software sales doesn't mean a hill of beans right now other than for marketing reasons. Or to put it another way, when Transformers or Shrek III or Ratatouille were relesed on DVD, every one of those titles sold more copies their first week than both formats have sold in combined sales since inception! See what I mean?
post #2726 of 4687
Originally Posted by Lee Stewart View Post
David:
I agree.
post #2727 of 4687
David, do you find it a bit telling like I do that if they do come out at CES to make an anouncement one way or the other, they won't have the Christmas sales data yet particularly for hardware, so it seems unlikely they could be basing the decision solely on the future outlook of either platform. This makes me wonder if they've been given a big money-hat by one side ala Paramount.
post #2728 of 4687
Dave, do you have insider info that makes you want to take this bet? Or is it just a strong hunch?
post #2729 of 4687
I agree.
You do?
But you posted this:
Robert,
You agree that a WB announcement would be totally disruptive to CES - but they are going to do it anyway?
post #2730 of 4687
BD-ROM Part 3 v2.1 mandates support for 3 consecutive B-frames in VC-1 when EPS <= 1s.
  Back to Forum: HDTV Software Media Discussion
This thread is locked
