Hey guys,
Alright...so here is my problem.
Currently I have a sound system set up with a Sony receiver. I have a TV also, which has only 1 video input. I have a Wii in which I have its video cable connected to the TV, and the audio in an input on the receiver. This works fine. Now, last night I got a dvd/cd player that I wanted to hook up to the receiver/TV as well. But..as I said, there is only 1 Video input on the TV.
So far, I have put the audio cables and put them from the DVD player into an input on the receiver, however, to solve my lack of video inputs on my TV, I have a possible solution, but I just want to run it by you guys.
My receiver appears to have 1 video/audio output area as well. I was wondering...what if I take all 3 cables from my Wii (audio and video) and put it in an input on my receiver; take all 3 cables from my DVD player and put them into another input on my receiver....would I then be able to just take a video cable and put it from the video output to the video input on the TV, and be able to switch between the Wii's input and the DVD's input from my receiver? If I did this, do you think the video that is being outputted would switch between the Wii and DVD? I mean...where there are video inputs, and only 1 video output...I would assume that is how it'd work?
Hopefully you guys can help me out,
Jeff
Jeff
Go to the local Wal-Mart (or similar) to get your cables. They have been my source for all cables except HDMI (those I buy from Monoprice.com).
