AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Do I want this plasma? Want to buy NOW!
post #1 of 9
OK, I'm set on buying a plasma NOT over $1,400 (total). I always thought Panasonic was really good, but people here seem really experienced so I thought I'd come for your kind words of wisdom.
The best choices I found:
http://reviews.cnet.com/flat-panel-a...?tag=pdtl-list
and
http://reviews.cnet.com/flat-panel-a...5.html?tag=lst
I'm a little worried about the "poor" segments at the end of the cnet reviews. Do you guys suggest getting something from a company other than Panny? I want a good plasma to watch movies and play videogames. I want to buy it over this weekend, too. Before I spend the money I saved up somewhere else haha!
I have a couple more questions. About burning the TV in, if that's what it's called, what do I play/watch for a 100 hours to take care of that? What settings? And for how many hours a day can I let it be on?
The other thing is callibration, do I get it after that process? And where would be a good place? Best buy?
I would ask for a good site to buy the TV from too, not sure if that's allowed.
Oh wise AVS dieties, please enlighten me!
post #2 of 9
Some help, please?
post #3 of 9
Originally Posted by Eliasoz View Post
Some help, please?
Everything you need to know and more is in the PX75/PX77 Owners Thread
post #4 of 9
Don't rule out Samsung. It scored the same as the Panasonic but didn't have the floating blacks and didn't fail as many geek box tests.
post #5 of 9
Thanks RandyWalters.
Which Samsung do you mean Nuance?
post #6 of 9
CNET reviewed the 5064, but it is the same panel as in the 54 and I would imagine the 42 inch version will perform the same way (I think its called the 4254).
post #7 of 9
Great product, low price. Keep in mind though for a few hundred more you can get a 50" if the size works for you.
post #8 of 9
Oh, alright thanks Nuance.
Cleveland, if it did I would've considered it, but 42" is pretty much the perfect size for me right now.
post #9 of 9
Under $1,400 - Panasonic, Samsung, and Hitachi. The Hitachi doesn't have as good black levels as the others. Just make sure that you break in the plasma before playing video games. Enjoy!
