Someone recommended a particular brand & p/n of a banana plug which is a Monoprice JX 74047. It doesn't appear these will accept the speaker cables from the rear of the plug, only the side which would be fine for my tower speakers, but not my Yamaha receiver. The binding posts on the back of my Yamaha are so close together, the side-insert type just won't work for me (not enough room). I actually need both, screw-type plugs where you can insert the speaker cable into the rear and also the side. Any recommendations!
Ken
Ken
