"With recorded media, MS allows you to use the default third party filters that you tweaked just with one exception: EVR. Since its own filter, you can not change its merit value which is set to 00200000 while classical Video Renderer' 00800001. And both WMP and MCE will use the default Graph in their background; believe me. (but of course you can make your custom Graphs)
On the other hand when you put a DVD, MS will use its default filters including his EVR on those both application."
"Quote:
Originally Posted by CodeThief
So are you saying that you'll never be able to use EVR in MCE unless I play a DVD (where I don't need the HA anyhow!!? "
Untill finding a way to tweak EVR as default renderer, you won't be able.
http://www.avsforum.com/avs-vb/showthread.php?t=896920
Yes; thanks to codechief to boost me to figure out that issue.
Lets start:
Some tweaks first;
regedit:
HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrenentVe rsion\\Explorer\\Advanced
"SuperHidden"= (set to) 1 (you made all hidden files appear)
boot
_ _ _ _ _ _
From the Start Menu find the "Command Prompt" and right click on it. From the popup
menu select "Run as Administrator". A Command window will start.
Wriite "regedit"
Regedit popup window will open.
Go to the key
HKLM/SOFTWARE/Microsoft/Windows NT/CurrentVersion/WinLogon.
Now add (from the Edit menu) a new key.
Name this new key "SpecialAccounts".
In HKLM/SOFTWARE/Microsoft/Windows NT/CurrentVersion/WinLogon/SpecialAccounts
create a key named "UserList".
In HKLM/SOFTWARE/Microsoft/Windows NT/CurrentVersion/WinLogon/SpecialAccounts/UserList
create a new DWORD entry ;
Name this entry "Administrator" and
set the value to "1"
exit and boot
_ _ _ _ _ _ _
Open Radlight filter manager(right click on exe and"open as admin" click "direct show filters" and choose Cyberlink filters "preferred+1
boot again
_ _ _ _ _ _ _ -
Last step:
Making EVR default renderer;
First you gonna decrease the prioraty of the classical Video Renderer.
Open Radlight Filter Manager as admin and under Direct Show Filters find out Video Renderer; click on it and click "copy CLSID";
open regedit and navigate copied CLSID under PC after finding it just right click on this CLSID (it is on the left side)
go to "advanced", go to "owner", go to "administrator"and click "apply"and mark the "full control" box and "OK"
Move to the "FilterData" on the right side and click on it and change the first line(0000 line)
with this:
02 00 00 00 00 00 00 20 00 and "enter"
boot
Second you gonna make EVR default Renderer:
open Radlight Filter Manager as admin and under Direct Show Filters find out Enhanced Video Renderer; click on it and click "copy CLSID";
Second move to the "FilterData" on the right side and click on it and change the first line (0000 line)
with this:
02 00 00 00 01 00 00 80 00 and "enter"
boot.
Merit values has been changed by force; anyway enjoy with your new default EVR renderer.
GraphEdit, WMP and MCE will play even "recorded fies" on HA mode with new "default" EVR Renderer anymore.
Best!
"Quote:
Lets start:
Some tweaks first;
regedit:
boot
_ _ _ _ _ _
Wriite "regedit"
Go to the key
exit and boot
_ _ _ _ _ _ _
boot again
_ _ _ _ _ _ _ -
Last step:
with this:
boot
with this:
boot.
Best!
