For a number of reasons I have to start pulling wire in my house in a week. The Si that I have engaged will not have the sytem designed until after that time and will not have the wiring schmatics, etc prepared until a few days after I have to start pulling wire.
I have a fairly large home with 30 zones of audio/video. I also will have climate control, security cameras, security system, telephone, cable tv, satellite tv, ethernet and a few shades hooked up. I am using Crestron. The question is this. Even though the System has not been designed, can I pull lots of wire to each location without technical interference and the only risk is that I have not pulled enough or the correct wire to each location.
To minimize the risk of not having enough wire,could I pull four separate home runs of Cat 6, three separate runs of quad shield RG6, two separate runs of Cat5(e), two separate runs of Cresnet, one separate run of Crescat-D, another separate run of Crescat-D-HP and and a final run of Crescat-Q.
I think that all this wire run from the head end to each location should be sufficien and is probably overkill, but I am facing a dilemna in that the System will not be fully designed and I have to start wiring at least the first floor of a three floor house.
What problem can you detect so tha ti may plan for them and try to avoid?
