Just finished adding another shim to my CRT array, a la (thanks!) Owen, for a total of 2.25" - 3 shims of 3/4" each, 4 of them - to my 73" Mit. I added a spot of white glue between the shims and under them, for stability. This makes half again the amount of shimmage I had before today, with just 2 shim thicknesses each x4, for 1.5" of shimmage for the last few months -
Took this opportunity to reclean the lens tops, it had been a year or so since last time, made a noticeable difference. Mit's HDreadys don't need the deeper optics cleaning, they don't allow an air gap between the lenses and the coolant covers, like the Elites do.
I think my shots are being compromised by being in jpeg, which I have heard reduces the res automatically. I checked my cam and can't find any way to redo any of that inside the cam, so it must by the automatic Windows uploading from my cam. Any input welcome on that. Kodak Z712 IS.
After redoing the focus, geometry and convergence - grayscale and colorations stayed the same as before, basically all by eye on the colorations - here's the results -
[/url]
Slightly overexposed, but appropriate to the brilliance of the runway
[/url]
[/url]
Hard to get the crowd shadow details and still have the diamond sparkle without it white crushing out
[/url]
[/url]
Slight movement blur on this one, mostly on her outfit. But check out those abs!
[/url]
Blur on this one only on her right shoe and at the top of her rack (no not that one, the one she's WEARING...!)
[/url]
