Originally Posted by
Mark_A_W
I've stayed out of this thread as I basically think it's a pointless pissing contest more about cameras than projectors...
But Mike, are you KIDDING ME???
Your shots are blurry. They are ALL blurry. You go on about 1080p, when they look like compressed Xvids, let alone DVD.
The colours are way oversaturated.
Cliff's and Russ's images are nice eye candy, nothing more. But they at least are sharp.
I'm sorry Mike, but I just can't keep my mouth shut any longer.
I appreciate what you're saying here, but in the future it would make more sense if you understood what's going on with these shots.
First,before you comment about colors being "over saturated" first understand that it maybe from a cheap PS camera, because THERE are NO COLOR ADJUSTMENTS on my setup!
And if you actually knew first hand of some of the shots, you'll know that most if not all of the nature HD shots have been color boosted.
So rather than comment based on not having a true reference, it's best to keep quiet.
Also, my shots may appear to NOT be sharp, and that may also be due to the PS camera, which does not do too well on focus, because of it's lens.
However, those who are aware of what I have been posting, without a doubt have been able to clearly see how well I'm resolving the bandwidth. There's a plenty of shots that have proven that, but for some reason, that same old low resolution color boosted shot keeps popping up..
The one pixel on test, well Mark.How many times do I need to post that?? And being the only one on these and other threads that has done so, and has done so at even 1920x1080P @ 72hz, why do you continue to challenge me to do so?
Do you want me to post it one more time, or would you feel better If i had someone to come over and report back to you how well things look in person. And let me assure you of this, there's no focus issues, even at 1080P 72hz.
So rather than continue (this not your first time) post this nonsense and send me PM's with the same base less comments.
Can my setup 100% resolve 1080P 60 or 72hz, absolutely! Do I need to FURTHER prove that to you or anybody else - no!
Also, and take this from someone who actually knows what fully resolved 1080P looks like. I've said this so many times in the past, when 1080P is fully resolved, there's a huge difference in the colors, the range and intensity of the colors is something much greater than what's there with the lower resolutions. You see, when you've experienced this, you don't always need the test pattern, the colors will also confirm how well it's being resolved.
And if I was that concerned with your constant criticism, I'd get a better camera. But i see no need for that, since there are so many others out there that appreciate the shots as they are. And truly understand what's going on with them, that I'd just rather continue to post themas they appear. And if it continue to cost you more grief than what you keep indicating, then you should contact AVS and let them know about your on going grief and how troubled you are about my shots not being as good or better than others. And maybe they're delete the thread or band me from posting my shots here...
But until that happens, I'll keep posting them as simple as I take them.No sharpening, touch-up, enhancements or better cameras.
Sorry they've been causing you so much grief..
