I know I mentioned getting back to further dialing in the beast later today, but that will have to wait until another day..
I also have to play with the camera, because I'm having a problem with it capturing shots from the G90. I'm sure I'll need to find the best exposure setting. Things are a little different with the G90.
Other than some of the other virtues I've already mentioned about this G90, there are two that I'd like to also mention. One being the gamma circuit feature that's not found any any of the other CRT projectors that i know of, with the other being, the intensity of the image.
Both are huge benefits this projector has. The gamma circuit may play some role in the improved punch that it has. While at the same time, the gamma feature almost makes an external gamma device almost not necessary. That's after the improved low end or fixed low end I'm now getting.
Watching the gamma curve or effect on a scope was interesting. And the way it ramps up without clipping the signal is also neat. It not only ramps the low end, it effects an almost entire IRE window.
Really neat..
