Originally Posted by Randy Mathis
In the setup menu of your 805 you can determine which processing schemes are used with each sound format. It may be that your 805 is set to output DD when receiving a DD EX signal. Just change it in the menu of the 805. I set my receiver to give me exactly what is on the disc and I change it with the surround button if I want more processing. This way I know what the player is sending to the receiver.
I think this is true for the most part. Most folks will leave it on "Last Valid" as a preset listening mode for the various audio input formats and NOT what it is supposed to be, e.g. TrueHD should presets to TrueHD.
But Dolby EX is not one of the listening mode you can preset to. It is on its own menu item, under Setup >>> Audio Adjustment >>> Dolby EX. The only option is "Auto" or "Manual". Auto will allow you just two listening modes as an option, Dolby EX or THX Surround EX. While Manual, you can select additional listening modes compatible with Dolby EX.
Overall Home Theater Experience
Audio **
Subtitle Legibility ***
Center Channel Dialog Clarity
Must be good to be you!!! $$$$$$$$$
This stuff is addictive. I mean, I still got an eye out for the Sony 550 and the Oppo now
, I guess!
Surround Sound Detail
Low Frequency Effects
Balanced Surround Sound Volume
Movie Stupid [So-So] Spectacular
