Joerod, I'd like to read about your results as well. It'd be interesting to compare our findings. In the meantime, I'd like to share more of my own experiences with the player so far. I've also added a few quick pics of the player and accessories. Below is a brief list of some player tidbits.
Unit is fairly light (built more like an A20 than an XA2)
Made in China
Flimsy tray
A tad noisy during loading. Laser pickup makes high pitch sound. Nothing significant.
Extremely quiet during playback. I couldn't hear the fan at all, even up close.
Still has problems with some discs at menu screen. Might be a java issue. Takes you to menu screen, but doesn't let you highlight any options.
Player speed:
From off to tray eject - 20 sec
Avg load time until picture appears on screen - 20-25 sec
Still very slow for the POTC movies - 60 + sec to load
Scan speeds and chapter skipping is still a bit sluggish. Comparable to the Sony S300. Not nearly as fast or smooth as the PS3.
Will resume playback if stopped, but will reload and start over if ejected from the player.
Leaving the audio output at bitstream will allow for DTS and DD decoding through the receiver and will automatically switch to PCM uncompressed audio when selected on the disc.
Still no bitstream passthrough for TruHD or DTS-MA decoding yet, if ever.
http://render2.snapfish.com/render2/.../of=50,590,442http://render2.snapfish.com/render2/.../of=50,590,442http://render2.snapfish.com/render2/.../of=50,590,442http://render2.snapfish.com/render2/.../of=50,590,442http://render2.snapfish.com/render2/.../of=50,590,442http://render2.snapfish.com/render2/.../of=50,590,442
