AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Center speaker output not working
post #1 of 3
Hello -
I have an Onkyo DS-777 and the center speaker is no longer working. Tested the speaker; it's fine. Connected a different speaker to the output, and no sound.
So-
Do I have to replace the whole thing because of this, or could I connect it to a power amplifier and then connect the speakers to that?
Or, is this just crazy talk?
Bill
post #2 of 3
Your idea of using the center preout to an external amp might be an option, but not sure I would spend a lot of money for an amp, just for the center channel. You might try checking the manual on how to perform a "reset" of the microprocessor maybe that will clear it up. not sure.
post #3 of 3
Have you checked all the speaker setup/configuration settings?
