ok, the T775 arrived as expected today. I'll get right to it.
There is good and bad, but first things first:
first impressions...very solid build quality. The unit is larger than I assumed it would be from pictures on the website. The toroid unit is very large and takes up most of the left side of the unit (when viewed from the front.) After powering up...I like the look of the receiver. The display is very bright and easy to read. The buttons are plastic and a little clunky, but the volume knob is very solid. Connections on the back (at first glance, but more on this later) appear to be really well constructed. All connections are gold-plated and intelligently organized, as can be gathered by the pictures on the NAD website.
after hooking things up...first blemish is revealed: unless you have very small wire guage speaker cable or use banana plugs you will be VERY frustrated when connecting your cables. The binding posts are, as far as I can tell, completely proprietary types and although they are built very well, with very solid build quality, the inability to connect my spade lugs was really frustrating for me. I had to clip the spade lugs off of my speaker cable, strip the wire and then connect. I have relatively large guage cable (10 guage) and I could barely fit it into the posts (I'll see if I can get some pictures uploaded later). In addition, there is no way to connect the speaker cables from the underside of the binding post: you must connect them from the top, which forced me to get creative with my cable organization and makes me nervous that they will pop out eventually. It appears that NAD is doing everything possible to influence their users to adopt banana plugs. I should note that if you have banana plugs you will likely find this aspect of the setup very painless, and this issue is forgiveable given the solid build quality of unit overall.
audio setup/calibration...the audyssey appears to work as advertised. It is a bit unsettling at first, however, as the manual leads the user to believe that the auto calibration and multiEQ room correction will be completed in separate steps. I spent a good 10-15 minutes looking through all the options in the menu before I realized that both features are completed in the initial calibration step. The T775 will output test tones to learn speaker size, crossover freq and distance, (it will do this for multiple listening positions), and then it will perform calculations for about 2-3 minutes for the room correction. The room correction algorithm is user selectable (after it has been calibrated of course) from the main menu (DSP settings) or directly from the remote. The options are off, flat, audyssey, or NAD (the latter obviously the NAD proprietary response curve advertised on the website). I haven't yet had a chance to fully evaluate each of the settings, but switching quickly between them while listening to source material reveals a great deal of audible difference between each. I can say that it appears that the NAD eq is a bit more bass heavy than the audyssey curve. Of course, I could just be influenced by what is written in the manual, which implies that the NAD curve emphasizes the low end a bit more: "...Thus if we effectively 'remove the walls' with room correction, and set the speakers for flat response, you may find this sounds to bright in the treble and too weak in the bass region..." To me that means that they roll off the high end a bit and beef up the bottom. Only a careful analysis of my room acoustics would answer that for sure. However, I will say that the overall "balance" of the acoustic range did appear to be noticeably better. A review of the audyssey really isn't part of this thread, but rather whether or not it works in the T775. It does. So far I am impressed.
And now we come to the source of my frustration for the past several hours. HDMI audio. The HDMI audio works, but with my PS3 as a source, I can only get it to pass 2 channels of the multichannel LPCM audio. I cannot pinpoint the problem, but I will tell you that I went out about 2 hours ago to purchase an additional HDMI cable to rule that out as a source of the problem. The PS3 thinks it is sending the audio just fine, because in a 5.1 channel mix (such as a movie soundtrack from a blu-ray disc) only the left and right front channels can be heard in the mix when I choose LPCM audio. And this isn't a case of the the PS3 down-mixing the 5.1 to a stereo track--the information simply isn't there. the echoes of the dialogue can be heard as they would be in the left and right speakers for ambiance, but it is clear that the remaining channels are not being processed (for whatever reason) by the T775. I am confident that it is not the cable, so it must be the PS3 or the T775. I have to assume it is either the T775 or an incompatibility between the PS3 and the T775. However, I am skeptical that it has anything to do with the PS3, since it is passing audio over HDMI... This is a digital connection, only the source or the processor can extract the channels! Perhaps this is a timing problem? I am at a loss since I have been spending hours trying different PCM sampling rates (selectable in the PS3), different program material, and different HDMI cables. Another interesting point -- the PS3 will automatically detect what PCM modes it can output via HDMI, and when using this feature while connected to the t775, it only detects 2 channel modes. For me, this is a big problem. If anyone has suggestions I would gladly welcome them. Of course, it passes the dolby digital and DTS bitstreams just fine, but I bought this receiver to listen to uncompressed audio, not only my old DVD collection.
Other impressions...aside from the obvious frustrations over not being able to use one of the features that represent a main factor in my decision to purchase the T775, I am very pleased with the unit overall. My first impressions of the sound quality are more than favorable. The amplifier appears to have room to spare, and then some! It has that signature NAD sound as well--buttery smooth with good open detail in the top end and emphatic punch in the low end. Again these are impressions after only very little listening. I can tell you that when comparing the unit to my previous setup, my impressions are still favorable--I like the NAD more, quite a bit more. That is saying something coming from a well received pre/pro like the Reference 30...I know this could just be a psychosomatic effect from wanting to like the NAD, but I've heard enough audio gear in my time (hopefully) to keep from falling into that trap.
Provided I can get this HDMI audio issue worked out, I will be very happy with the unit. However, I'm afraid that if it can't be fixed, it isn't a drawback I'm willing to live with.
If anyone else has gotten their hands on one of these, can you tell me if you are having similar issues?
I'll have more when I've had more time to play with it, and (hopefully) get the multichannel uncompressed audio working over HDMI.
John
John
