AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The NAD T775/T785 AVRs w/ HDMI 1.3 Thread!
The NAD T775/T785 AVRs w/ HDMI 1.3 Thread! - Page 6
post #151 of 4166
Not sure whether this is relevant to your situation but a similar issue non of the less
''whilst i was adjusting the settings on the ps3, i went into 'audio output settings' and found that you could manually change the settings - i took out the linear pcm 2.1 settings and hey presto i was able to scroll through the stereo and surround sound options on the onkyo. It would appear that if you leave the 'audio output settings' on Automatic on the ps3 it will only play mp3s and cds in linear 2.1 !!!''
Ken
post #152 of 4166
Ken
Ken, thanks for the info. Unfortunately I have tried manually setting the modes. I still have to confirm one more setting with NAD support before I can state definitively that the 775 will not accept multichannel LPCM, but it is looking like this is the case. As dan1010 stated, however, it appears that NAD is going to have a fix for this, so it should only be a temporary problem.
post #153 of 4166
Ok mate,
Keep us informed
Ken
post #154 of 4166
Lost in the shuffle here is the question regarding DSD bitstream and the T775. I would assume that it does not accept a DSD stream, but someone else would have to confirm as I don't have a player that will output a DSD stream. dan1010: do you have have a player capable of DSD, and if so, can you confirm this?
John
post #155 of 4166
Seems odd they would not test that it could accept Multi Channel PCM before shipping these units.
post #156 of 4166
I'll have to caution potential buyers who want to get multichannel LPCM out of the T775/785/175.
I would hope NAD addresses this issue for models that have'nt been shipped yet. I have a T175 on order.
post #157 of 4166
Originally Posted by dan1010 View Post
I also received one of the first T775s and have the same problem
are you using a PS3 with yours as well?
post #158 of 4166
exactly the information I'm after.
post #159 of 4166
Again we need someone with a player capable of a native DSD stream to confirm, but for my part I can tell you that the PS3 will output a stereo SACD track as LPCM 88.2Khz. That at least works well. I'm of course hoping I will eventually be able to take advantage of a multichannel SACD recording either through a native stream or by LPCM over HDMI.
post #160 of 4166
good point. I think the 765 and 775 shipped before the 785 and 175, although I could be mistaken. You might luck out.
Interesting note regarding this point... In the marketing fluff at the beginning of the manual, under the subheading "upgradeability" (or whatever word they use, I don't have it in front of me), it makes no mention of the modular construction touted on the NAD website. An interesting omission from the manual, of all things. They talk about RS-232 and software upgrades, but no hardware swapping. I get the feeling I (and dan1010) got a very early build of the 775.
post #161 of 4166
This may be a premature question given the unit won't accept multichannel LPCM but is there a level adjustment for the LFE channel? For example, a movie converted to LPCM would want the LFE boosted 10dB but an SACD probably wouldn't want the LFE boosted. It has taken some other manufacturers as much as a year to acknowledge and fix this HDMI "bass bug" and enable boosting the LFE for movies so I hope NAD doesn't have to go through the same learning curve.
post #162 of 4166
As promised, here are some early pictures taken before I completed setup. The quality isn't very good, I'm afraid--the only digital camera I have is my cell phone...avsforum.com is only letting me upload one at a time so this will likely take a few posts to complete...
post #163 of 4166
My Pioneer DVD600 AV Player can do this (send Native DSD Stream down HDMI)
But I do not have my T785 yet to test it
John, Any feedback from Nad yet - did you get to speak to someone (nad management) to confirm your issues.
post #164 of 4166
post #165 of 4166
not just yet. hopefully today before 5 PM GMT-5. I honestly don't anticipate hearing anything encouraging during this call, but I'll give it a shot. I'm still waiting for a reply to my web help query.
post #166 of 4166
unfortunately without a multichannel LPCM track to test, I can't be sure. All of the speaker levels appear to be adjustable no matter what the input, however. E.g., it works with 2-channel LPCM.
post #167 of 4166
It's a major disappointment and surprise that NAD fumbled the HDMI after all this waiting.
If it requires a new board, I don't see how it could be less than months in coming; f/w upgrades take that long more often than not.
The only possible upside for me is that by the time it's fixed the new Sherwood Newcastle receivers with the Trinnov EQ could be out; it sounds like it may equal or exceed Audyssey.
"This may be a premature question given the unit won't accept multichannel LPCM but is there a level adjustment for the LFE channel?"
As John said, that could be handled with different user memory settings.
Which reminds me of something else I've wanted to know - John, Dan, what are the tone control capabilities?
post #168 of 4166
major disappointment indeed.
tone controls are defeatable, and adjustable bass and treble. they are digital, of course. Is that what you were looking for?
post #169 of 4166
can you tell me how long it took them to reply to your question via the web help center? I received a message from them saying that "due to vacations" it would likely be a while before anyone got back to me...
It took a couple of days. It's a little odd, sometimes they are quick and other times it can take a while to get a response.
post #170 of 4166
John
Sorry I do not ...
post #171 of 4166
Actually yes, and I have a Toshiba A20. It is definitely the AVR reporting it does not support the 8 channels of LPCM. This has been confirmed by NAD and they have an "in warranty solution," for this, not exactly sure if this means hardware or software update but at least it's covered.
post #172 of 4166
Probably, and most likely the reason for our LPCM over HDMI issue.
post #173 of 4166
Can't handle LPCM?
God...almost beyond belief...
post #174 of 4166
I used the web support. I'm going to go through my dealer contact next ... Will keep you posted.
post #175 of 4166
Actually I believe they are analog tone controls (controlled digitally). There is one for dialog also.
post #176 of 4166
Originally Posted by oink View Post
Can't handle LPCM?
I don't think this product was beta tested. [We] are the beta testers.
post #177 of 4166
Are the Tone controls for the front speakers only or can you adjust the centre and surrounds
post #178 of 4166
Front speakers only, except for dialog, which is only on the center channel I believe.
post #179 of 4166
I can confirm this.
post #180 of 4166
I just spoke with my dealer. He said it isn't the first he had heard of it, and "likely not the last." This is definitely a known issue. He is following up with NAD support, and I am waiting on a call from them as well.
will keep you posted.
John
