AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The NAD T775/T785 AVRs w/ HDMI 1.3 Thread!
The NAD T775/T785 AVRs w/ HDMI 1.3 Thread! - Page 9
post #241 of 4166
So with the available fix in regards to the 8 channels of LPCM, is it still not possible to pipe 5.1 SACD through the HDMI into the Nad ?
post #242 of 4166
once the fix is in place, if your player can convert multichannel SACD to 5.1 LPCM channels, you will be able to send multichannel SACD over HDMI.
what you will not be able to do, however, is send a native SACD DSD bitstream over HDMI to the NAD T775/T785/T175. That feature is not scheduled for inclusion (to my knowledge) for the foreseeable future, although with modular construction one cannot wholly rule it out.
Once I have the fix, I will let you know how everything works. I don't expect it immediately, though, as it sounds like NAD is still figuring out the best way to handle it.
post #243 of 4166
John,
Curious if the T775 will convert the two LPCM channels you do get to 7.1 using DPLIIx or NAD's proprietary mode.
post #244 of 4166
Did NAD indicate what you will have to do for the fix? Return unit to a repair center/dealer/do it yourself?
post #245 of 4166
Pretty much verbatim, but I got the same response from NAD support:
"On the very first T775 units, 8 channel LPCM over HDMI is not supported, only 2 channels. However, NAD will cover the cost of a solution which will enable 8 channels of LPCM over HDMI. Please contact your dealer to have this work done."
Anyway, it's a big relief to know it's only the early units and that there's a fix for them.
post #246 of 4166
John,
yes it does. this function works currently without the fix.
post #247 of 4166
it will apply the following surround algorithms to any two-channel source: PL, PLIIx (movie or music), EARS (NAD proprietary), DTS Neo6 (movie or music), stereo, or enhanced stereo (all channels driven).
post #248 of 4166
not yet. If I had to guess, I would assume this is a software/firmware upgrade. I'm guessing this because according to rumor the other AV units in this line are being delayed due to firmware updates (the firmware that the T775 probably should have received). Whether or not NAD will allow it to be done in the field is the real question--I'd rather not ship my T775 back to the dealer.
As has been suggested in the T175 thread, all three units should really have the same firmware as they all contain the same processing hardware. the fact that the t775 was released earlier than the others suggests that it was released without the upgrade.
Anyway, if it is a software upgrade, I am very hopeful that it will be field-upgradeable. I'll let you know what I find out.
post #249 of 4166
Don't all or most 7.1-channel receivers do that already?
Sanjay
post #250 of 4166
"Don't all or most 7.1-channel receivers do that already?"
Yes, but it seems that if HDMI is involved "do" can become "should do but doesn't".
post #251 of 4166
I believe that it will, as it does this with PCM and 2.0 Dolby/DTS over digital now.
post #252 of 4166
My dealer informed me this morning that the fix is a new circuitboard. I'll have to ship it back to the dealer...the fix is not available just yet but it shouldn't be long now...
post #253 of 4166
So how do you figure we will know between the original 775 and the corrected ones. Will the corrected ones be identified by serial #. I would hate to get one in and then have to test it only to find out I did not wait long enough.
post #254 of 4166
well, I can't help you there. I highly doubt NAD will make this information public. However, if you are unlucky enough to get one that requires this update, NAD is covering the cost of it, so at least it is free. The only downside is the hassle of going through the update process.
Your best bet is to work with your dealer before purchasing, and ask them to test LPCM functionality.
post #255 of 4166
Can a lucky owner post a picture of the 775 remote? Curious what it looks like. From what I understand the 785 has a remote with a display?
post #256 of 4166
don't have picture handy at the moment but it is almost identical in appearance to the HTR-2 remote. There is a picture of that on the NAD website.
post #257 of 4166
Does the HTR3 use the same ir-keys like the HTR2? Or is it possible to change them? I want to have the T775 and my old T762 in the same room.
post #258 of 4166
Rec' answer to question from NAD: T785s will not be affected by HDMI 2 channel problem.
post #259 of 4166
Don't know if anyone else reported this, but the 775/785 product sheets and 775 manual are now on NAD's web site. The 775 & 785 product sheets are almost exact copies except for the power specifications and description of the remote.
The docs also mention a Ipod dock that will be available that connects to a data port to support control and display info by the receiver.
They also mention a DAB radio connector for use with an optional module. Thought this might be also for HD-radio, but doing a search shows that DAB may be European system only. The manual also mentions a XM connector but doesn't show up on the drawing of the back of the unit.
The manual is short (44 pages) but does answer some of my questions. Like if A+B speakers are selected then the source is down mixed to stereo.
post #260 of 4166
Sure would be nice to know what serial #s of T775 are affected by this LPCM problem as I am expecting mine in tomorrow.
post #261 of 4166
I don't think my unit has a DAB radio connector, but I'll verify this tomorrow. It does have the XM and iPod connectors, however.
I did mention this earlier in the thread in response to your question, but I'm glad you found the manual regardless. I find the manual to be relatively lacking in information...
post #262 of 4166
Originally Posted by ak2000 View Post
Should would be nice to know what serial #s of T775 are affected by this LPCM problem as I am expecting mine in tomorrow.
You could try posting this question on the NAD website help center, although I doubt you'll get an answer by tomorrow.
post #263 of 4166
" I find the manual to be relatively lacking in information..."
Yeah, not a word about Audyssey Pro.
post #264 of 4166
Thanks, must have missed your reply on this. Thanks for all your answers!
Maybe the DAB is only European models and XM on U.S.?
Are you bi-amping your fronts?
post #265 of 4166
The Bi-amping option seems very vague in the manual
775 owners!
Can you Bi amp the fronts using the surround backs AND listen to surround modes (5.1 or 4 channel stereo etc) at the same time OR can you only listen to 2 front channels if you select bi-amp ?
Ken
post #266 of 4166
775 owners!
Ken
I Bi-Amp my fronts using the Backs on the T775 and can still listen to 5.1. So yes, it does support all 5.1 surround modes while bi-amping. It's too bad there is no bridging capabilities though ...
Also relating to your bi-amp question, when bi-amping your fronts using the back amp, the back speaker pre-outs are still active for the back speakers. Meaning you could actually still get 7.1 if you used another amp for your backs.
post #267 of 4166
I thought Bi-amp was another word for bridging on the Nad, i.e. doubling the amplification for the fronts
post #268 of 4166
No ... bi-amping can only be used if your speakers support it. Your speaker must have two separate binding posts, which basically split your speaker in two. You then drive these two portions of your speaker with separate amps.
Bridging is when you use two amps together to double your output voltage, which theoretically gives your 4 times the power ...
post #269 of 4166
oh, i thought the back surround and fronts could be bridged
Thanks for the info
Ken
post #270 of 4166
Not at the moment. I'm waiting until I get my 775 fixed before I go through running cable for the setup. I have a 6.1 setup so I've been debating getting rid of the rear surround channel. I find that the rear surround channel opens up the surround soundstage quite a bit so I'm rather loathe to remove it.
I've never bi-amped my fronts...have you done this? Do you find the sonic gains significant enough that it will make me forget about the rear surround channel? Just curious...
