Probably, but no guarantee how soon afterwards it will be available either. Also consider the card will prob be around $600 assuming similar price as AM200. So unless you think you are getting a good deal on the 787, do you want to spend extra to replace the card so soon after you get it? Of course the new model will probably be alot more too. But you have consider the cost of the 787 and the new card.Originally Posted by oliMac
Hi,
I plan to buy a T787 receiver shortly (before the end of the year probably) and I have the same concern about NAD not supporting MultEQ XT32. If NAD adds MultEQ XT32 support next year does that mean that they will release a dedicated MDC module so we could upgrade any receiver?
thanks
Hi,
thanks
