AVS › AVS Forum › Display Devices › Display Calibration › Spydertv is it worth it?
post #1 of 4
I figured i could buy one off ebay and after i use it sell it back...but i was wondering is it really worth it.
I saw that the regular one doesnt mention nothing about grayscale..and i dont know alot about this stuff and was wondering if thats a huge deal.
And can it adjust anything that i cant change?
post #2 of 4
also i have a samsung hlp series DLP so if anyone has used it on this model that would be nice to hear from
post #3 of 4
I just got a new version of this SpyderTV in Hk which can calibrate projector too. It was easy to use n I love it. The only problem is whenever you have HDMI connection between your DVD n display, the 'Tint or Hue' on the display menu will be white-out. I don't if there is a way to go around it, so I can still calibrate 'Tint or Hue'.
post #4 of 4
you'll need to calibrate your TV once a year at the minimum anyway so why sell it after using it? For my PC monitors, I calibrate them once a month.
