AVS › AVS Forum › HDTV › HDTV Recorders › Pace TDC779X (aka Tahoe Analog CableCARD) Release Notes Thread
post #1 of 6
This thread will only contain release notes for Pace TDC779X (aka Tahoe Analog) firmware releases. Please don't ask questions on this thread as it is strictly for release notes. General Tahoe Analog questions, or specific questions about releases can be posted on the Tahoe Analog thread.
post #2 of 6
9.56-9.60 AVS Release Highlights
These releases are all the same but VOD support differs.
Disclaimer: These are highlights from the release notes with issues that are relevant to AVS users.
1. The highest trick mode speed may be faster for some content.
2. Time bar jumps around during trick operations.
3. Captions aren't temporarily disabled if you do a trick operation.
4. Faster swaps to Music Choice channels.
5. Unplayable recordings after reboot.
Note: Please don't ask me if site X is rolling or has rolled out 9.56-9.6. I can't comment on this. I also can't comment on whether or not you should request the update from your cable company.
post #3 of 6
AVS Release Highlights:
1. Time shift issues with Music Choice content.
2. Video loss scenario on analog channels.
3. Swapping issues with DMX content.
Note: Please don't ask me if site X is rolling or has rolled out 10.15-10.19. I can't comment on this. I also can't comment on whether or not you should request the update from your cable company.
post #4 of 6
This is the first release of the Passport Echo EPG by Aptiv running on Pace set tops (TDC779 in this case).
This release is initially only available in areas served by Suddenlink. These fixes have been made since the last beta firmware release.
1. Audio muting issues when surfing to/from HD channels.
2. Parental PIN controls can be reset from the DAC (i.e. network server).
3. High value content works over 1394.
4. Wrong information sometimes recorded.
5. PPV works reliably.
Known bugs:
1. Replay button doesn't always jump back 10 seconds.
2. Closed caption overlapping.
3. Series recordings may not automatically restart after a reboot.
Note: all of the issues described above are relevant only for Passport Echo. They do not occur with the current TV Guide firmware releases.
post #5 of 6
10.57-10.61 AVS Release Highlights
1. Improved display of closed captions.
2. Error handling for CableCARD validation state (9) scenarios.
3. Info banner pops up when using Arris VOD.
4. Recordings don't start automatically after a warm reset.
5. Improved error handling when using Arris VOD.
6. Tandberg VOD client displays error 3106.
7. Increased volume levels audio on HDMI connections.
8. Add diagnostics dashboard.
9. Concurrent HD VOD works.
10. Diagnostics now displays CRC errors from the HDD.*
*This information is inaccurate in this build and should be ignored.
post #6 of 6
12.48-12.51 AVS Release Highlights
1. CableCARD infinite reset cycle.
2. Loss of DVR service if background tuner is on VOD channel*
*This release disables HDD spin up/down to solve item #2.
  Back to Forum: HDTV Recorders
