AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › The sony bravia s3000 calibration, and user settings thread
The sony bravia s3000 calibration, and user settings thread - Page 2
post #31 of 239
Does any one have any settings for KDL-32S3000 connected to the PS3 with HDMI. I'm using the TV for games and Blu ray movies only.
post #32 of 239
ok...here are my settings for HD and SD over HDMI with Time Warner cable...I’ve had the TV for a little over 2 weeks and really like it, but I’m still tweaking...
Picture mode: Standard
Backlight: 2-4 depending on the lighting situation within the room.
Picture: 72
Brightness: 49
Color: 47
Hue: G3/? Still haven’t decided…
Color temp: Warm 1
Sharpness: 6
Noise reduction: off
Mpeg: low
ADVANCED SETTINGS...
All OFF but
Color space: Wide
If anyone tries these settings, please respond and let me know what you think…
post #33 of 239
Originally Posted by Coltaine79 View Post
not really finding much success with the settings provided here. anyone else using something different (with say, Component input)?
Here is for componant and Video 1 Cable directly to tv in dark room
Cinema
Backlight 2 min
Picture 70 60
Brightness 52 50
Color 43 42
Hue 0 0
Color Temp W1 W1
Sharpness min min
N/R off
MPEG N/R off
Black Corrector off
Ad CE off
Gamma off
Clear White off
Color Space wide
Live Color off
Standard
Backlight 5 2
Picture 76 70
Brightness 57 53
Color 48 37
Hue R2 0
Color Temp W1 W1
Sharpness min min
N/R off
MPEG N/R off
Black Corrector off
Ad CE off
Gamma off
Clear White off
Color Space wide
Live Color off
Vivid
Backlight 7 6
Picture 84 66
Brightness 48 47
Color 72 55
Hue R2 0
Color Temp neu neu
Sharpness min min
N/R off
MPEG N/R off
Black Corrector off
Ad CE off
Gamma off
Clear White off
Color Space wide
Live Color off
post #34 of 239
this is good we've got some new calibrations!!, keep em comming!
post #35 of 239
my-planet's settings work best for me and my s40. To each their own, but turning down the backlight to 2 or 3 results in a horribly dark and faded picture, (in standard mode with neutral tone) requiring maxing out the contrast or brightness. But I guess everybody's eyeballs are different.
post #36 of 239
Any one with any settings for the PS3 connected with HDMI? Its only for Blu ray movies and gaming.
post #37 of 239
Anybody have a calibration for the Sony Bravia 40" KDL-40S3000 720p LCD HDTV with HD DIRECTV? I'm using HDMI to connect the two.
I'm trying out the calibrations y'all have made, but would like to know if anyone has HD service with DIRECTV and have come up with a good calibration.
Glad I found this forum. Good stuff. I need the best picture possible for my Christmas gift to myself.
post #38 of 239
bump.... anyone get really good ps3 settings yet?
post #39 of 239
Good settings will be good for whatever you have hooked up, generally speaking.
post #40 of 239
my ps3 settings are really similar to my cable settings up above, I just tweaked the picture, brightness, and color a bit. just play and see what looks best to "your" eyes.
Good Luck, and let me know if you come up with something that you feel looks better. I'm always open to check out other peoples setting!
post #41 of 239
Hey Mav...saw in a previous post that you had the 32in, wish i could be more help, just wanted to let you know that the panel in the 32in is different from the 40in and up, so the setting may be different...just food for thought, you may already know this though.
post #42 of 239
Thanks for letting me know and the help. I had no idea.
post #43 of 239
I just purchased my KDL-40S3000 about a week ago and have been researching thousands of posts \\ pages worth of calibration techniques for these Bravia TV's.
I currently have a PS3 via HDMI
Xbox 360 on component, but I am going to change it to VGA when I get home
Will have Comcast HD via HDMI or component tomorrow
I plan to start really configuring my TV tonight to hopefully have the best settings for each input that I use, and depending on whether its a PS3 game, or Blu-Ray movie, SD Signal, or HD.
I'll post all of my settings once I have finished my calibrations.
~Tony
post #44 of 239
ok...here are my settings for HD and SD over HDMI with Time Warner cable...I've had the TV for a little over 2 weeks and really like it, but I'm still tweaking...
Picture: 72
Brightness: 49
Color: 47
Hue: G3/? Still haven't decided
Color temp: Warm 1
Sharpness: 6
Mpeg: low
All OFF but
Color space: Wide
I use yours for my HD DIRECTV setup. Looks really good. If there's a setup that's better, I'll be happily surprised.
post #45 of 239
Alright, as promised... I think all of these configs look amazing, I believe I have Cinemotion turned on for all settings because it should only affect things that are 24fps anyways. For the PS3 I recommend using more than one color profile
Comcast HD & SD signals, Motorolla DVR - COMPONENT
Picture Mode: Standard
Backlight: 8
Picture: 90
Brightness: 54
Color: 52
Hue: 0
Color Temp: Neutral
Sharpness: 15
Noise Reduction: Med
MPEG Reduction: Med
Black Corrector: Low
Advanced CD: Med
Gamma: Low
Clear White: Off
Color Space: Wide
Live Color: Off
PS3 Blu-Ray Movies- HDMI
HDMI RGB Range (on PS3) set to: Full
Picture Mode: Cinema
Backlight: 3
Picture: 78
Brightness: 50
Color: 64
Hue: 0
Color Temp: Neutral
Sharpness: 1
Noise Reduction: Off
MPEG Reduction: Off
Black Corrector: Off
Advanced CD: Off
Gamma: Off
Clear White: High
Color Space: Wide
Live Color: Off
PS3 Games - HDMI
HDMI RGB Range (on PS3) Set to Full
Backlight: 6
Picture: 90
Brightness: 63
Color: 58
Hue: 0
Color Temp: Neutral
Sharpness: 1
MPEG Reduction: Off
Advanced CD: Low
Gamma: Low
Clear White: Off
Color Space: Wide
Live Color: High
Xbox 360 - VGA CABLE
Picture Mode: Video (only available w/ VGA)
Backlight: 7
Picture: 90
Brightness: 44
Color Temp: Neutral
Hope that helps!! If you have any suggestions please let me know, but I'm loving this setup so far
post #46 of 239
thanks!, ill be sure to try those settings out.........
post #47 of 239
Trying those out right now. I'll let you know. My Comcast HD cable is hooked up via HDMI though. Will that make a difference?
post #48 of 239
It may yes, you may want to try out a modified version of the PS3 settings. Of course, it may look fine w/o changing. Not sure!
Let me know though, I may even hook mine up via HDMI just to give you a more definite spec
post #49 of 239
Ok, I saw some changes I needed for my Comcast @ night, so I set up a Cinema profile.
Comcast HD & SD @ Night - COMPONENT
Backlight: 4
Picture: 75
Brightness: 55
Color: 50
Hue: 0
Color Temp: Neutral
Sharpness: 3
Noise Reduction: Low
MPEG Reduction: Low
Advanced CD: Off
Gamma: Off
Clear White: Off
Color Space: Wide
Live Color: High
hope that helps you guys
post #50 of 239
Backlight: 8
Picture: 90
Brightness: 54
Color: 52
Hue: 0
Color Temp: Neutral
Sharpness: 15
MPEG Reduction: Med
Advanced CD: Med
Gamma: Low
Clear White: Off
Color Space: Wide
Live Color: Off
Backlight: 3
Picture: 78
Brightness: 50
Color: 64
Hue: 0
Color Temp: Neutral
Sharpness: 1
MPEG Reduction: Off
Advanced CD: Off
Gamma: Off
Clear White: High
Color Space: Wide
Live Color: Off
PS3 Games - HDMI
Backlight: 6
Picture: 90
Brightness: 63
Color: 58
Hue: 0
Color Temp: Neutral
Sharpness: 1
MPEG Reduction: Off
Advanced CD: Low
Gamma: Low
Clear White: Off
Color Space: Wide
Live Color: High
Backlight: 7
Picture: 90
Brightness: 44
Color Temp: Neutral
I love your settings, its the best I have seen for this model. Any one with a ps3 and this tv should use these settings.
post #51 of 239
I love them too. The only thing I disagreed with right away was the Sharpness setting for the PS3. It looks too soft to me, but I'm not going to change it. See if I get used to the look.
post #52 of 239
Note that the brightness (black level) setting can vary. You'll want to check with a proper setup screen to make sure you have the right black level, so you aren't too light (no true blacks) or too dark (not enough shadow detail).
post #53 of 239
I'm glad you guys like them
I think the shadow detail is good, I have the Backlight adjusted for different lighting situations and inputs. If you have a better recommendation though I would be happy to try it out.
post #54 of 239
Picture: 72
Brightness: 49
Color: 47
Color temp: Warm 1
Sharpness: 6
Mpeg: low
All OFF but
Color space: Wide
I haven't tried these out, but you may want to set up more than one color profile (standard \\ cinema) or something like that so you don't have to adjust the brightness.
I have to use one color profile for all comcast tv situations because there's no way I'm gonna get my wife to change color profiles while she's watching tv(lol)
post #55 of 239
It's all room- and taste-dependent.
If you have a lot of light coming into the room, you may want the backlight up higher (depending on material).
We have a window across from the TV, but for daytime kids' show viewing, I still keep it at Cinema 1, BL 3, Picture 80, Brightness 48, Warm 1 temp (etc etc). Looks pretty good to me. As close as I care to try to get it.
post #56 of 239
What are your full settings?
post #57 of 239
See page 1 of this thread, posts 13 and 14.
I may have tweaked slightly since then.
And I don't use HDMI on the TV anymore, as that now goes to my projector.
Just HD cable box over component to the TV.
post #58 of 239
ah, sorry about that. Thanks
post #59 of 239
Cinema mode
Backlight 2
Picture 80
Brightness 51
Color 50
Color Temp - Warm 1
Sharpness Min
Noise Reduction Off
MPEG Noise Reduction Low
Black Corrector Off
Advan CE Off
Gamma Off
Clear White Low
Color Space Wide
Live Color - n/a unless Color Space set to wide
I like these for my comcast, I think better than my previous settings - thanks. I went with neutral color temp instead, and medium on both noise reductions.. I think I set Live Color to High too...
Thanks for this setup for my comcast
(But the Ps3 settings still are awesome)
post #60 of 239
I used a new calibration disc aimed for HD content, created it myself with the ISO image file, I forgot what it's called but I'll find out when I get home from work. Anyway, I calibrated my 32S3000 with it, and the picture looks more natural, colors vibrant yet not too vibrant. So far it's good:
(HDMI)
Backlight - Min ( so far it enhances black levels, use to have it on 3 )
Picture - 80
Brightness - 54
Hue - 0
Color - 39
Sharpness - Min
No noise reduction used
All advance settings set to Off
Color Space - Normal
Blu-ray movies look great, not too dark to cause black crush, but not too light to have a wash out appearance. Component settings are similiar except for the following:
Color - 41
Picture - 75
