Originally Posted by
EWL5
The firmware info can only be seen on your TV/display so looks like your receiver and TV had to be on too. The only way to get out of the screen is to power down. That flashing red and green is normal when reviewing firmware. Just don't hit STOP? during the screen or you will reflash to defaults.
Hey man thanks for the info , I just got off the phone with a tech from Marantz , And the same as you said , I had to turn on the TV & RECV, DUHHH
.. I was looking on the bluray display for the info LOL
Mine is Version 1.103 also . I also asked the tech this is the lastest and most up to date version , actually he more or less said only version .. AND I QUOTE if any other frimware come , you will have to send the unit IN, for an update , they will not send a disc or over the internet,, Due to Liablity. That
sucks...
( bad thing) I did try to hit stop when I was trying the above , So does this mean I have to go in and rest all my setting again ? LMK on this , I think I also hit the stop when I had the TV on too ,, Man what a pain.. I will have to go back and check it all this week end , BUTTT,, ( by pushing stop I did'tn hurt nothing did I ?) like have to send it in to make it work right? lmk ASAP on this it will drive me crazy all day thinking i F*&^K it up..thanks so much for your he;p
Also he told me that my Deep color being grayed out is okay so its not on . I have to have a Tv to support it , which I dont
and the PIC adjustments sould be done on the TV 1st calibrate , Or try running it in 720P instead of 1080I , I will try this this weekend..
