Well, did a bunch of work on this thing last night and got it pretty good looking.
My gamma is still low at about 2.05 but I got rid of the big drop at 40,50 and 60 IRE, it's caused by the auto iris. Currently have it set to min. and it is almost straight and is as high as I can get it.
The delta E is now almost perfect at less then 2.5 from 20 to 100.
Color temp is dead on as well.
The only thing off is the secondaries but these are read with an 8 color bar pattern on the screen from my iScan HD. If I use the getgray dvd they are near perfect so I'm discounting these values.
So here are the numbers.
Cal:i1LT/HCFR
Iris min
pic 90
bright 48
color 53
hue 0
color temp warm1
ADVANCED
black corrector high (helps my gamma)
gamma off
clear white off
color space standard
live color high (helps the primaries)
WHITE BALANCE
R gain -2
G gain -2
B gain -15
R bias 6
G bias 4
B bias 7
If anybody with HCFR wants to try these out and see what they get it would be interesting to see the comparison.
Once I zip my files and figure out how to post them here I will do so.
Troy
Here are my HCFR files, both from my iScan and dvd player.
Â
HCFR_Files.zip 2.1865234375k . file
