I've pulled the old drywall and weak batts of insulation off the walls of my detached garage. I'll prime the wood, soon, to help seal it against decay. But there are still some gaps where one can see light come in from the outside, so putting up some kind of vapor barrier after priming but before insulating seems like a good idea.
Photos and more info are here:
http://www.avsforum.com/avs-vb/showt...8#post11565958
I used some "Great Stuff" foam to seal some areas on one wall already, but I think that something with more coverage is a good idea, on the interior of every exterior wall, while it's all exposed.
What's the right stuff?
And can I really use 2x the regular amount of insulation, since I'm building a whole second frame and wall?
