I have two questions to ask:
1. I live in pakistan and receive my cable using a set top box and a two foot dish. Here is the link of my provider
http://www.dishtvindia.com/
The cable i receive is not high definition. Which Tv tuner would i have to use to connect my set top box with my htpc. How will i input sound from the set top box to my xtreme gamer soundcard. As i shall be using creative gigaworks 750 speakers for the sound.
2. What is the best way to upscale standar dvd to high definition format using htpc.
