AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What is the best LCD or Plasma screen for around $1800-2000?
post #1 of 12
I don't know if I am allowed to ask this but I went for it.
I am looking for a 46"+ TV. (MAYBE 42".)
1) One of my main concerns is the difference between 120hz and 60hz. Basically how big of a difference is it, and what are the advantages?
2). Can I get a 120hz TV that's in my price range?
Thank you in advance,
Mnk.
post #2 of 12
Samsung LN-T4661F.
post #3 of 12
Is the Samsung LN-T4661F at 120hz?
post #4 of 12
Nope. If you want 120Hz, you need to pony up more cash than what you have in mind for your budget.
post #5 of 12
Sony KDL46V3000 - You can get close to your budget with this model with best of class procesing for price point and quality. Check out resellerratings for models and pricing and ratings of vendors. If your budget cannot stretch perhaps the S3000.
Some of the better features include:
10-Bit Processing and 10-Bit Display
While it's great to state that a TV is capable of creating billions of colors, it's a whole lot better when you have a display that can actually display them. That's the logic behind Sony's 10-bit processor and 10-bit display. Sony follows 10-bit processing with a 10-bit panel, allowing 64 times the levels of color expression than an 8-bit panel. What that translates to is smoother transitions from color to color and subtle color changes faithfully reproduced.
24p True Cinema (24p Input Capability)
Many movies are filmed at 24 frames per second (fps) and prime time TV programs are video taped at 24p. Seizing on an opportunity, some studios are taking a purist approach and encoding high definition video content such as Blu-ray Disc in 24p. Sony wisely takes advantage of this by including 24p output capability on their BDP-S1 Blu-ray Disc player. It makes sense that the KDL46V3000 would include 24p input capability. The benefit? Images are smooth and natural looking. Once you experience 24p video it will be hard to view video without it.
post #6 of 12
Originally Posted by westa6969 View Post
Sony KDL46V3000
And before you ask, that Sony is NOT a 120Hz, either.
post #7 of 12
I've read some threads about 120hz. So, is it safe to assume that a pretty high end Plasma = a 120hz LCD in terms of reduced motion blur?
In other words, if I buy a plasma I would not need to worry about 120hz/60hz and motion blur, correct?
post #8 of 12
Sounds good, surely consider this. So at what fps do other normal LCDs display at?
post #9 of 12
Who cares? His budget is such that unless he goes with pukevision panels with poorly performing 120 it doesn't matter - I'm recommending quality. I'm viewing a $6500 LCD and I don't give a crap about it not having 120 - it doesn't lessen what I view daily as my Sharp handles most motion excellent without it. There are many I could recommend but they are obviously above his budget unless he goes with a weenie size 40" panel and a less than desirable quality.
Many posters come in here and perhaps want us to recommend a Ferrari at the price of a Ford Focus. I do not believe in buying low tier panels or wasting time even evaluating them -your usually buying technology from previous generation sets on those. I'd ignore the 120 unless your willing to save further and up the budget and then a Samsung 71 or a Sony XBR4 are the two titans battling it out as well as the Toshiba (provided it has the green push resolved). BTW - Samsung makes a kick ass plasma in the 5084 but not certain it falls into your budget yet.
post #10 of 12
Who cares? His budget is such that unless he goes with pukevision panels with poorly performing 120 it doesn't matter - I'm recommending quality. I've viewing a $6500 LCD and I don't give a crap about it not having 120 - it doesn't lessen what I view daily as my Sharp handles most motion excellent without it. There are many I could recommend but they are obviously above his budget unless he goes with a weenie size panel and a less than desirable quality.
I know but I get an impression that he is looking for 120Hz panel with that budget.
post #11 of 12
I dont require a 120hz panel. I am a serious PC gamer, and I am looking forward to playing on a good TV set. Because of that, I am picky about motion blur. If you are saying that there are panels that can satisfy my needs, then good for me.
post #12 of 12
120Hz is starting to sound more and more like a marketing gimmick (kind of like 1080p).
I don't doubt that 120Hz does something, but most seem to not like it's effects.
