AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Long HDMI run (approximately 100 feet)
post #1 of 6
I need to run a rather extensive HDMI cable (approximately 100 feet) and it needs to be run through conduit outdoors. Does anybody know what the viability of this is? If running outdoors is not a problem would it be best to use some form of premade fiber-optic cable, pure fiber-optic cable with booster/switches (or whatever) at the ends, or a cat5 solution? I would prefer something that was perhaps fiber-optic and HDMI 1.3 capable. I'm willing to run extra CAT5 through the conduit just in case. I have heard pros and cons to different solutions. I know with a premade cable you need a six-inch bend radius and that probably wouldn't be feasible because I wouldn't want the conduit protruding from the house that much. I've seen everything from the gefen solutions to a ridiculously priced Teradyne one.
Any suggestions would be greatly appreciated.
post #2 of 6
Intelix just issued a press release on this Cat5e/Cat6 solution:
http://www.intelix.com/press/070827_..._F_Release.htm
Could be worth a look...
post #3 of 6
Thanks, preferably am looking for a fiber-optic solution as I have heard the others are finicky.
post #4 of 6
post #5 of 6
Here's a certified cable for up to 300 m
www.vizionware.com
post #6 of 6
Gizmodo had good set of articles on HDMI for cable length as well as performance under set of various resolutions. Start here with the last article:
http://gizmodo.com/gadgets/top/the-t...iii-282725.php
